Results 1 to 6 of 6
Thread: shocks/springs question
    Nic92's Avatar
    Nic92 is offline Rough As
    2002 VYS S1
    Mar 2011
    WA
    Default shocks/springs question
    Hi guys,
    just wondering, transfering the springs from a VY S to a VY Clubsport, is it possible?
    or would i need to buy new ones?
    also can i use the shocks from the vy s?
    thanks
    vn executive series 1 v6 1989
    Sep 2011
    maryborough
    id say so there both irs. but the front spring are 2 suit v6 and u wanna put them in a v8 so it would sit lower and the front would be softer but would fit. but the back would be a straight swap
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    The LS V8 engines and ecotec V6 in VT-VY's in most cases use the same front springs as they are similar in weight.
    In the early VT the Holden V8 was 40kg heavier than the ecotec V6 so then there were different rate springs.
    So using your old springs shouldn't be a problem.
    HSV shocks are slightly better than Monroe GT Gas (not Sports), what are the shocks from your old car.
    HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
    VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    Quote Originally Posted by Surfwagon View Post
    they are Bogue Turbo (damn service place put them in when i gave them the springs to put on)
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    As for the springs usuing thiose shocks shouldn't be a problem and if you liked how it rode and handled in the Spac then should be the same in the Clubby.
    The Clubbies (infact all the HSV's) are slightly heavier than equivalent Commodore sedan but all over not just in the front like in the early VT series1.
    The extra weight in VY's comes from things like full body kit, bigger brakes if fitted, bigger front swaybar, extra interior gear.
    As they all the little things added together make extra weight.
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    yeah thanks for that
  1. Replies: 4
    Last Post: 22-11-2010, 09:15 PM
  2. [SA] TRADE. Lovells HD springs > fe2 springs and shocks
    By GTP 85 in forum Parts And Other Items For Sale
    Last Post: 26-03-2010, 12:32 PM
  3. Lowering car, change just springs or springs + shocks
    By wildeagle44 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-01-2010, 06:38 PM
  4. Quick question on VT shocks + springs
    By Slippy_Trippy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-06-2009, 03:26 PM
  5. FS: Whole Suspension Setup (Springs , Shocks, Struts) King Springs
    By ssmate in forum Parts And Other Items For Sale
    Last Post: 01-11-2007, 06:24 PM
