Results 1 to 5 of 5
Thread: Low coolant
    sajid_stato is offline Stato_89
    vs statesman
    Aug 2009
    rowville
    Default Low coolant
    Hi guys first of all thank you for any assistance.
    I own a vy clubsport manual and its my first v8 since im a convert( turbo=v8) . im loosing coolant and i find that i have to top up everytime i drive. i checked all the hoses and they seem to be intact. the only leak i could find was from these two metal hose looking kind of thing probabli transmission cooler or something......its leaking out of that. any help would be appreciated . thank you
    VY SS
    May 2011
    Auckland
    Pretty sure the manual doesn't have a tranny cooler. Can you take a photo of the pipes? Could it be your ac pipes and your seeing condensation? I would gets radiator place to pressure test your cooling system. Could be nearly anything.
    VE International 3.6L
    Jun 2011
    Gold Coast.
    Pressure test need urgently. Radiator place or your local service guy. Holden dealer can do it to.
    VY SS series 1
    Jan 2012
    perth
    i had the same problem with my ss turned out to be a cracked radiator and i couldnt find any leaks cause it was spraying onto the block under pressure and evaporating easy fix though as was under warrunty still
    VY SS UTE
    Jan 2011
    SE QLD
    As above, look to replace the radiator and waterpump, new hoses and heater tap. All in one go is peace of mind.
  1. Brown sludge in coolant reservoir + coolant level dropping
    By phuecn in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-11-2010, 08:03 PM
  2. VX Coolant leak from Coolant Reserve?
    By anarklov3r in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-09-2010, 09:50 AM
  3. Low level coolant light staying on, even though coolant has been topped up
    By luckyluciano in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-05-2010, 08:40 AM
  4. vx ss using oil and coolant! Please help
    By jay_wr8 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-03-2010, 07:21 PM
  5. what coolant
    By smc69 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-04-2009, 08:49 PM
