Results 1 to 3 of 3
Thread: VY SS Key/Immobiliser fault
    VY SS Commodore
    Dec 2009
    Default VY SS Key/Immobiliser fault
    Ok, can't find any discussion that is helpful so here I go...
    We have a VY SS and for the last couple weeks, every now and then when we start the car, it will stall after a few seconds. The little lock symbol on the dash flashes until we hit the unlock button (key still in ignition). Turn the key again straight away and off we go. We didn't think too much of it until tonight when we got stranded at the shops.
    We locked the car with the remote, came back about an hour later, and the remote wouldn't work. 3 buttons for unlock/lock/boot release. All 3 dead. Knowing what would happen, we tried anyway, and put the key in the door to open the car. As soon as the door opened the alarm went off and we put the key in the ignition to start the car. It just stalled because we can't disarm the immobiliser. I'm assuming our issue for the last couple weeks probably has something to do with our current situation.
    Anyone experienced something similar? Is it possible that our little light flashing has been due to the battery in our key running flat, and we just need to replace it? I'm hoping it's nothing too dificult, will be talking to Holden first thing in the morning, just looking for other feedback as well. Obviously will also provide the solution, when we come across it. Cheers.
    maginoodle's Avatar
    maginoodle is offline Donating Member
    vy series2 ss crewman
    Apr 2006
    Hi, you will need a new remote. Also you can try bending the ring around the ignition switch outwards to give the key better contact with it(it also sends the imobiliser signal through it).
    Cheers Shane
    heres my ride, i know its not much but its mine
    http://forums.justcommodores.com.au/...-ss-crewy.html
    and heres my new project
    http://forums.justcommodores.com.au/...ml#post1104629
    VY SS Commodore
    Dec 2009
    Thanks for the tip Shane, spoke to a guy from Holden and he seems to agree that we need a new remote. Got a mobile locksmith coming out Friday morning so fingers crossed
  1. Engine fault light comes on and stays on but fault code says no fault?
    By hildahoop in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-06-2011, 05:46 PM
  2. Is this VP fault, V6 fault or just bad luck?
    By MyVPIsFasterThanYourVP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-12-2006, 10:46 PM
  3. immobiliser
    By crg07 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-04-2006, 03:27 PM
  4. Fault light came on but reports no fault
    By VRBerlina05 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-08-2005, 07:21 PM
  5. immobiliser
    By ducatis in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-07-2005, 05:38 PM
