Hey guys
im looking at buying a 04 vy s but its supercharged, just wondering will i be able to simply take of the superccharger and make it run like a normal 6? or would i need to replace things or would it create problems?
reason i cant have the supercharger is because im on my p's.
thanks
It will be a decompressed engine..
Basically, you will need to get a full ecotec top end (heads up), as well as computer (and I believe wiring loom), and after all of that, you will end up with something slower than a VY exec..
May as well just get a VY S-Pack that already has an ecotec V6, or wait until your off your P's and get a Supercharged V6 or even better, a VY SS V8.
Originally Posted by Jasper44
Including car parts (VS, VT, VX, VY, WH etc), my WH Statesman, and other things listed on eBay.
Just risk it and get it! Get work to buy it for you and make it a work car!!!
Im about to get off my Green P's and i cant wait to get a nice SS v8.
But OP is right i just getting a normal V6 un modified a new top end is gonna cost you an arm and a leg and won't be worth it.
Debadge it? Police won't know unless they check under bonnet..?![]()
People like you OP are the reason P platers have a bad name. Hai guiz can I please buy a supercharged model and take it off. Then of course the people saying yeah man just do it. Facepalm man up deal with the fact you can't get a forced induction model spend less money on a crappy car first then go to the forced induction route when your on your open's.
Just buy a normal v6 for ####s sake, why the Phuck would you even consider that in the first place...
From what i can gather a l67 with the supercharger off would likely run like shit anyway cause the compression is set for boost in those engines. Not to mention you would need an intake manifold, Heads, plenum and prob throttle body. Then the ecu would need to be tuned to suit as its tuned for supercharger.
Better off buying a V8 and removing two plugs and leads.
Silver Certified.
So what you are gonna take off the supercharger, spend money to get it running half decent, then what spend money to make it supercharged when you get off your p's??? Is that correct? MAKES NO FRIGGIN SENSE!!! Buy a NA, look after it and get as much back for it as you can and buy a Supercharged six or go straight to a V8 when you go on your opens.
Just take the charger belt off. Will be fine. I wouldn't bother but. Why don't you buy a s1 VT l67 that way you can drive it legally. or go a sv6
Or a get a switch to turn it off, just like in Mad Max...![]()
jus outta curiosity "VS V6", why is this supercharged VY th only thing you have eyes for at th mo? do you need to sell your VS to buy it? maybe jus buy th VY and keep drivin th old one til you're allowed to get behind th wheel of a blown car? how much are you lookin at payin for th VY?
sorry only jus read your reply to wraith so you've answered my Q. good luck with your decision
Buy the supercharged 6 don't be a bitch
I was more referring to the other idiots saying go for it vs v6 but I suggest you edit your post.
You do know the police can run your plates and it will come up on there screen as a "supercharged commodore " ....
