Results 1 to 5 of 5
Thread: A few questions....
    VY Berlina Series 1
    Jan 2012
    Albion Park
    Default A few questions....
    G'day fellas, I'm new to this forum and havent long bought my car.... Anyway, wondering if some of you could help me out here.
    Its idoling a little rough. What is the likely cause? Injectors are fine, so PCV pipe?
    ABS isnt working, ABS fuse?
    Looking to drop the car and stiffen it up a bit. Would a pedders kit be the way to go? And any ideas how much it cost?
    VY S Series 2
    May 2010
    If its idling a little rough i'd recommend cleaning the inside of the plenum as it gets a lot of crap built up in it... also the throttlebody and theres something else in the throttlebody that you should clean as well its called a something valve (as you can see i have forgotten what its called) anyway it controls the idle pretty much
    That should solve your problem
    VY Clubsport R8
    Sep 2010
    Check your IAC valve which sits on the top of your throttle body, there known to play up and fall apart inside which causes a rough idle.
    GothicKidd's Avatar
    GothicKidd is offline ლ(ಠ益ಠლ
    Series II VR Commodore
    Dec 2010
    South Australia
    Might be your O2 sensor? I've had plenum and whatnot cleaned, ran injector cleaner... Used premuim petrol.. and still had a little miss in my idle. Still yet to replace the O2 sensors. but they would cause problems. just sayin
    GothicKidd's Ride
    I push the pedal to the floor, smoke them up and go.
    VY Berlina Series 1
    Jan 2012
    Albion Park
    Cheers fellas.
  1. CAI questions
    By Toms 50th Ani in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-08-2010, 09:10 PM
  2. VS Questions
    By Nato B in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-05-2009, 01:46 PM
  3. SS ute questions
    By BANKS in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 24-10-2007, 02:17 PM
  4. A few questions
    By 97vt_exec in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-06-2006, 05:27 PM
  5. 2 questions about my vh
    By vhgrp2 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 28-04-2006, 11:05 PM
