Results 1 to 6 of 6
Thread: Vapour lock problem.
    VY 03
    Aug 2005
    Default Vapour lock problem.
    Anyone had this before? VID_20120116_180803.mp4 - YouTube (starts 0:19) Vapour lock?? Only happens after heat soak here is the list of changes i made that has caused this hideous start that will "sometimes" stall on me.. (only when hot)
    Mace manifold insulators
    New injectors (also tried another set no difference)
    Replaced valley gaskets.
    Most mechanics suggest fuel pump or coil pack. I have new coils prior to the problem same with vacume lines also changed fuel pressure regulator, water temp sensor, throttle position sensor,
    Could heat soak be causing a vacume leak?? or maybe moving the leads around disrupted them as there is a slight miss on idle And idle with sit on 750-700 and fluctuate. Any suggestions are appreciated cheers
    vs commodore
    Oct 2009
    Tamworth NSW
    You wont get vapour lock problems on these cars, as any excess fuel thats not used by the injectors is just returned to the fuel tank. With this type of fuel system setup, fuel is always cycling through the lines, so any vapour in the fuel lines would get pushed along through the return line and back into the tank.
    VY 03
    Aug 2005
    Ok thanks for that information. Did a smoke test found no leaks.. Also changed the leads and plugs to make sure, still there Someone suggested dfi module not sure how it would be related Car doesn't randomly stall on me while driving.
    Maybe the inlet manifold gaskets i changed were faulty?? Checked for oil in the water but no sign
    dumped vk 202 efi calais mok-up.
    Jan 2012
    berri s,a
    if it stalls when hot it would be heat sensor.. vy's have many faults..... i worked on the production line during vx to vy design change....best bet is go first to a holden dealer pay 60 odd buks to hook up the computer n see if its electrical or mechanical..... also maybe cheapest for ya buddy...
    VY 03
    Aug 2005
    It doesnt stall check that video has rarley stalled maybe 2x
    Heat sensor? I did change the water temp sensor. And you know what the funny thing is took it to holden they said no engine light no point I was like wow ok..
    VY 03
    Aug 2005
    Ok I had the intake manifold off and was looking at the pcv valve which i had out to check and clean at the time But when i was looking at it now (last weekend) there is a little o-ring that goes around the pcv valve and it didn't look to be sealed with fresh oil around and above the pcv valve not sure if thats normal Maybe that o ring not sealing is causing this problem.
    VT-VZ max elleries < PM
  1. Fuel Vapour Smell in Adventra. Is it a VZ problem?
    By Brownbro in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 08-10-2011, 04:31 PM
  2. vapour injected gas problem
    By rumper in forum VE Holden Commodore (2006 - ?)
    Last Post: 15-03-2011, 03:47 PM
  3. Lock nut problem
    By LightningVP in forum General
    Last Post: 17-10-2008, 12:36 PM
  4. Lock Problem
    By cunners3 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-06-2006, 06:14 PM
  5. Door Lock Problem
    By JTW008 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-05-2006, 08:21 PM
