Results 1 to 6 of 6
Thread: VY Calais Interior Lighting
    MEESEN's Avatar
    MEESEN is offline V8 6 Speed coming :D
    '03 VY
    Jun 2010
    Default VY Calais Interior Lighting
    Ok guys been ages since ive posted but i need some help once again,
    I need to know what bulbs are used in the interior lighting of a vy calais... heres the list of what ive got so far:
    Front Center interior light (2 map lights) : ??? x 2 (Are they BAX9s?)
    Door Puddle Lights: Festoon x4
    Rear passenger reading lights: ??? x 2 (Are they BAX9s?) (Also wanna know how to get these out)
    Glove box light: Festoon
    Center Glove Box Light: Festoon
    Boot Light: Festoon
    I think thats it
    Vz calais
    Oct 2010
    adelaide
    Yes interior front light are bax9's but have to be rewired to work.
    The rear map reading lights are festoon also and to remove just stick a small flat head into one of the sides with the hole and pull out.
    The boot light is also festoon but abit bigger than the door and rear map lights which are the same size.
    '04 VY II Calais
    Oct 2010
    Bayside, Victoria
    The map lights are BA9S, not BAX9S. The X has offset pins, they will not fit unless you grind off one of the pins. As has been said though, the wiring needs to be swapped around (red to where green is and green to where red is) and extended as the green wire will not reach to where the red is. I can rustle up some pics if you want?
    MEESEN's Avatar
    '03 VY
    Jun 2010
    if u can mate go ahead seen a pic of it somewhere and understand what your saying, but maybe just put up photo's in case someone else wants to find this thread usefull
    And i was meant to correct myself and say BA9's,
    But thanks guys
    MEESEN's Avatar
    '03 VY
    Jun 2010
    '04 VY II Calais
    Oct 2010
    Bayside, Victoria
    Here's a pic of the map light assembly. As you can see I've extended the green wiring (with light green wiring cause I was trying to be neat) and swapped the green with the red/brown wires
    Also found this info in a Word document on my comp too
    Dome lights – 2x BA9 BA9s Base Bulb with 9 High Power SMD LEDs Specifications
    Number plate – 2x T10 LED Lights, Bulbs & Accessories - SUPER BRIGHT LEDS
    Footwell lights – 2x T10
    Front park lights – 2x T10
    Rear roof lights – Festoon 37mm 3710-xHPx High Power LED Festoon Bulb Specifications
    Rear door lights – Festoon 37mm
    Front door lights – Festoon 37mm
    Glovebox light – Festoon 37mm
    Console light – Festoon 37mm
    Pretty sure the boot light is a 41mm festoon, however I'm not sure as I wired in a led light block (below)
  1. VN Interior Lighting
    By thesakeofit in forum ASR Audio & Electronics
    Last Post: 22-09-2010, 02:48 PM
  2. Interior lighting
    By matt8946 in forum VE Holden Commodore (2006 - ?)
    Last Post: 27-04-2010, 07:18 AM
  3. Interior Lighting
    By Chris92 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 11-04-2010, 06:30 PM
  4. interior lighting
    By nervesplit in forum General
    Last Post: 29-11-2004, 09:58 PM
