Results 1 to 9 of 9
Thread: Do I need to replace both Shocks and Struts?
    VY II Acclaim
    Jun 2011
    Shellharbour
    Default Do I need to replace both Shocks and Struts?
    I'm looking into lowering my Acclaim and trying to figure out what needs doing. My mate told me it's 99.9999% advised you replace the shocks because if you don't there's potential the springs can come loose.
    Is that true, and, is it also advised I replace the struts?
    Cheers.
    VY S Series 2
    May 2010
    What springs are you using?? Generally it is recommended that you get shortened shocks with springs lower than super low as a)your old shocks are probably rooted and b) the shorter shocks suit the springs better
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Depends how far you lower it but yes it is possible for the rear springs to fall out as the lowered springs arent as tall as standards so when the standard shock fully extends it allows the spring to fall out.
    For this reason its advised to fit matching short travel shocks. Another reason is to keep the shock operating in its intented range with the new ride height.
    Silver Certified.
    VY II Acclaim
    Jun 2011
    Shellharbour
    Well I'm thinking of getting low or super-low (i.e. 30mm or 50mm). I'm leaning more towards 50mm tbh.
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Yeah super low would look the best but will def need matching shocks.
    Silver Certified.
    VY II Acclaim
    Jun 2011
    Shellharbour
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    VY II Acclaim
    Jun 2011
    Shellharbour
    Is it worth buying those suspension sets on eBay? I see heaps of shocks/struts/springs packages on eBay for $599, is that a decent price? I haven't made any local calls yet, but what kind of price range have people paid for a proper setup plus installation and all?
    TMM's Avatar
    TMM
    TMM is offline OEM+
    VY Berlina S2
    Jun 2008
    VIC
    $600 is a good deal for King springs and Monroe GT Sport shocks.
    I paid about $1000 for king springs, kyb shocks, new strut top bushings and bearings, installation and alignment.
    Definitely get new strut top bushings/mounts, because the stock ones will have collapsed by now. It might be worth also getting a rear camber kit if you go for super lows - about $100 + installation, will help prevent excessive rear tyre wear.
  1. [SA] VZ Shocks & Struts
    By calay in forum Parts And Other Items For Sale
    Last Post: 07-11-2010, 09:40 PM
  2. Vs struts and shocks
    By sutty in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-09-2010, 08:55 AM
  3. struts and shocks
    By slappa. in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-03-2006, 07:15 PM
  4. Shocks and struts!
    By boojak87 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-02-2006, 05:53 PM
