Results 1 to 12 of 12
Thread: VE wheels on VY
    VY Exec & VZ Calais
    Mar 2010
    Default VE wheels on VY
    Hey fellas, I've got a VY Executive and just bought a set of VE SV6 wheels from my mate who's a wrecker for $500 with 245/45/18 tyres in great nick. I've bought a set of nuts from Holmart that have a larger flange to suit the studs on the VY, which will hold the wheel properly, and the wheels are now getting machined down, for $20 a wheel. What I'd like to know is how much will the speedo be affected by putting on these wheels? I'm coming from the stock 15s that have been on it forever.
    Thanks for your help guys.
    Sent from my Galaxy S2 using Tapatalk
    vyseriesII's Avatar
    vyseriesII is offline The V6 is MACEd
    2004 Vy S Series II
    May 2011
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    VT-VZ 18's only run 40 series tyres and the 45's that come on VE 18's may not clear your spring mounts on the front struts as the overall tyre diameter is around 20-25mm taller (radius about 10-13mm).
    HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
    VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
    VY S Series 2
    May 2010
    VY Exec & VZ Calais
    Mar 2010
    Dam, I thought it would be good, as I see 19s, even 20s on VY/VZ commodores. The tyres are virtually new, and didn't want to just remove them and buy new ones, as the only reason I bought them was for the good price.
    Factory Blown VY S2 Calais
    Jun 2005
    Brisbane Bayside
    It's not wheel size that's an issue, 20s are fine with the correct width/profile to suit your car. 15s will rub with the wrong tyre.
    Even if you got no rubber, you got the wheels for a good price. Find a second hand tyre dealer that will swap the tyres for you at little or no cost. Then you'll have no trouble with speedo, clearance or roadworthy.
    "You want fast, reliable and cheap ? You'll find a Commodore out there that can provide any two out of those three!"
    VY S Series 2
    May 2010
    well im running 245/35/19's and the clearance is about 4mm.... so i dont think 245/45/18s is gonna fit
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Quote Originally Posted by Dr HaxZaw View Post
    the 18s will be 23.6mm taller than the 19s, 245/40R18s would be almost identical to 245/35R19s in height.
    Silver Certified.
    VY S Series 2
    May 2010
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    the difference between 40 and 45 is 23.6mm?? is that radius or diameter
    35 on 19s vs 45 on 18s
    Diameter. 245/35R19 654.1mm 245/45R18 677.7mm
    Silver Certified.
    VY S Series 2
    May 2010
    yeah just wanted to check it was diameter you were talking about cause i was thinking possibly you were talking about radius and it wasnt computing in my brain lol
  1. [NSW] WTB. Vz SS, Vz Clubby, Vz SSZ wheels, any VE wheels that are machined to suit VZ stud
    By MattMarkey in forum Swap / Wanted to Buy / Trade
    Last Post: 10-05-2011, 11:37 PM
  2. VZ Calais wheels wanted - VY Berlina wheels for sale
    By I just want one in forum Swap / Wanted to Buy / Trade
    Last Post: 19-08-2005, 08:21 PM
