Results 1 to 6 of 6
Thread: VY headunit/speaker issues
    VN x2, VY SS ute
    Dec 2005
    S.A
    Angry VY headunit/speaker issues
    I recently had the left hand speaker (and split setup) stop working at the drop of a hat. In a ute with only two speakers, this is little annoying.
    I check the wiring loom at the door, the wiring behind the headunit, replaced the speaker with a known working one, but everything but couldn't fault anything.
    What I'd like to know is, where the does the wiring for the left-side speaker run? I may have a short or a break somewhere a long the way.
    Anyone have any ideas?
    VN x2, VY SS ute
    Dec 2005
    S.A
    Okay, worked it out..... the left hand speaker wiring runs along the right side of the car. The problem was one of the plugs behind the driver's side kick panel wasn't contacting properly.... moved the plug around and it worked.... Strange stuff.
    All I need to do it work out when I turn the volume up, it turn the volume down.....
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Quote Originally Posted by Shearer View Post
    I take it you mean when using the steering wheel audio controls?
    That's the most common fault with VY's! My volume up made it turn down, etc as well and track seek up would go down and vice versa. That's when I only had 40-50,000 k's on the clock too. I got hold of a new set of steering wheel controls off a member of this forum and and I havn't had it happen again-.... yet. There is another fix, but if you can get hold of some steering wheel controls and change them using the How-To on VY,VZ steering wheel removal, you'll be sweet.
    VN x2, VY SS ute
    Dec 2005
    S.A
    The steering wheel controls are fine. It's the headunit.
    It's not a huge deal, just annoying when I try to alter the Bass/Treble/Balance/Boost. Same as the volume, if I turn it up, it will go up 1 unit, down 3, up 1, then down a few more.
    VY Executive S1
    Feb 2012
    Hoppers Crossing
    I had that problem with my VY, when i would push the volume down button, it turned it up, and when i pushed the volume up button it muted it, then sometimes it would work like its supposed to... its a strange problem...
    Torquative's Avatar
    Torquative is offline Up and lets go
    WK Statesman, MY13 VRX Lancer
    Jun 2005
    Their based off resistance so when there's a problem it really plays with it as it gives false readings to the head unit.
  1. VX Audio Speaker/Headunit Problems *Help Needed*
    By VX Appeal in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-09-2010, 02:12 PM
  2. Few issues after headunit + amp install in VS
    By nathanVY in forum Car Audio
    Last Post: 15-05-2010, 10:20 AM
  3. Speaker or headunit issue.
    By And_ROOS in forum Car Audio
    Last Post: 01-06-2009, 12:51 AM
  4. vr doorpod speaker issues!!
    By Nicks in forum Car Audio
    Last Post: 05-03-2007, 09:32 PM
  5. VX Headunit in VT - Issues?
    By Lord-Data in forum Car Audio
    Last Post: 01-10-2006, 11:50 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
