Results 1 to 12 of 12
Thread: Towing with low profile tyres
    VP Berlina WK Stato
    Jan 2006
    Default Towing with low profile tyres
    I have a WK 5.7 Stato that I regularly use to tow a 2000kg Caravan, I use a Hayman Reese load leveling system I have 18/40/ 235 tyres.
    I recently did 400km trip with the van & knew the tyres were getting down, I decided to have the rears replaced while there & when they were taken off I was stunned to see splits right round the inner side wall.
    The Tyre guy at Bob Janes said you were lucky you got here & I believe him, these tyre are well within their load rating but now I'm not sure that low profile tyres are such a good thing when towing.
    Has anyone else had any expeirience when this sort of thing happening?
    Any help ideas apprieciated
    Noel
    SavVYute's Avatar
    SavVYute is offline Beatus ille
    VY S V6 Ute Series II 2004
    Nov 2009
    Duckburg
    The rear independent suspension setup would place more weight on the inside edge of the rear tyres. Is your Stato really down in the back with the caravan on?
    Sabbath''s Avatar
    Sabbath' is online now McKennock
    80 Series TD Landcruiser // Hustler
    Jul 2006
    What brand of tyre and how many KM did you have on them?
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    VP Berlina WK Stato
    Jan 2006
    The Stato sets level or just about, with the Hayman Reese 600lb kit fitted & yes the tyres had been there a couple of years & were down past the wear marks & I have to admit were not the best tyres they were Roadstones came as a package with the wheels.
    i was just surprised to see the splits I wish I had thought to take a pic.
    Just thinking now I should go for a Tyre with a Higher side wall with more flex
    Noel
    wraith's Avatar
    wraith is online now Hand over the dog bikkies
    95 HSV Clubsport & 89 MX6 Turbo
    Sep 2008
    Demonicaland
    Roadstone? I would say that's half the problem. Not to mention letting it get down past wear marker.
    VP Berlina WK Stato
    Jan 2006
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    VP Berlina WK Stato
    Jan 2006
    Thanks, yes I do I work for Coromal Caravans & regularly set up these hitches for customers so the setup is ok.
    I'd just never seen this sort of thing in tyres before & it started me wondering if I should maybe have say16" wheels for towing. ie: a higher profile tyre that has more flex in it.
    Noel
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Are you taking the extra weight of the caravan into consideration with regards to the tyres load rating?
    GOLD Level Holden Technician.
    315rwhp
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Inherent problem with IRS. The lower it goes, the more negative camber on the rear.
    The only way to fix it is to fit a 4 point adjustment kit to the rear and try to get as close to zero on your rear camber as you can.
    Ideally, live axle cars are better for towing as you won't get camber issues.
    Visit my Facebook page
    Quote Originally Posted by 191kieran191 View Post
    contact Not an abba fan he is the best
    Nuff said really.
    1999 VTII SENATOR
    YOU BUY!!!
    ALL SERIOUS OFFERS CONSIDERED
    http://www.carsales.com.au/private/d...o=Stock&items=[Make:HSV,Model:SENATOR,Series:VT%20II]&sort=default
    Hot House VY SS
    Jan 2010
    Putting something other than Chinese rubber will probably stop the problem. With a higher load rating
    GTP 85's Avatar
    GTP 85 is offline 291 hp @ the wheels
    VS v6 track car & VS SSenator
    Aug 2006
    Murray Bridge S.A
    Just replaced two 19 inch tyres on my car from splits in the inner sidewall. these wheels were previously on my live axle VS and had no problems, put them on my VR IRS to tow a reasonably light trailer and the inner walls started to crack?? The VR has a 4 point camber kit and the tyres were premium Dunlop SP sports. so devoed, had 60% tread left
    I think low profiles dont like the extra load and flex on the inside walls
    Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
    GT Performance RUF 231- NA 3.8L- 13.03 @ 103 Mph... A 12 is but a run away! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
    Daily Senator rep: http://forums.justcommodores.com.au/...ite-vr-ss.html
  1. How do low profile tyres handle in the wet ...
    By Hairy Eater in forum The Pub
    Last Post: 26-12-2006, 07:44 AM
  2. Low Profile Tyres
    By vzuterus in forum General
    Last Post: 20-01-2006, 10:30 PM
  3. low profile tyres
    By Tony2 in forum General
    Last Post: 04-07-2005, 08:07 PM
  4. psi for low profile 17 inch tyres
    By daniel VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-05-2005, 04:39 PM
  5. low profile tyres
    By Tony2 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-06-2004, 08:10 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
