Results 1 to 15 of 15
Thread: Urgent Help needed a post from Saudi Arabia :-)
    2003 Holden VY II Acclaim Wagon
    Feb 2012
    Taif Saudi Arabia
    Angry Urgent Help needed a post from Saudi Arabia :-)
    Hello All
    well i own a Acclaim wagon 2003 V6 and for the past few days it has developed a few issues which the Mechs here are not able to Understand Please help me figure them out
    1) it started to pour Allot of fuel in to the Cylinders so i got the Injectors Tested and Cleaned and they turned out to be fine and still its doing this i have recently changed all the plugs/leads and found out that they all had turned black and were wet and had a smell of petrol and the tail pipe also smells like petrol..
    2) After a long time if i start it it starts rough and gives Some smoke grayish White smoke to be exact and it does not grab any exhilaration untill its completely warmed up
    3) it has also blown a few plugs/leads maybe because of the excess fuel
    4) I Have Grayish white smoke when i rev the engine till 4000 Rpm multiple times
    what i have done so far
    have got the Injectors serviced
    have Changed All the Leads/ Plugs
    Have Changed all Lead Wires
    Have Changed a Coil cuz it was weak
    Have got the Air intake Assembly completely Serviced
    Observations
    The Oil is clean No Sign of Water
    The Coolant is Clean no sign of Oil in it
    The oil cap is not whitish or creamy
    and can someone please elaborate where the Petrol Pressure REg is Situated in this Engine and how it could be changed ??
    Well these Cars are very cool and Awesome Cars but they are not so much Recognized in The Arab world Specially Where i live because of these Sudden problems which the dumb Mechs are not able to understand and the Owner ends up spending thousands and still is not able to fix it
    Please Help me by sharing ur Experiences Thanks Alot
    VY S Series 2
    May 2010
    Have you tried O2 sensors? if these are gone the engine will run rich although i doubt it would run as rich as what your describing
    How many kms are on the car?
    VN x2, VY SS ute
    Dec 2005
    S.A
    Does it use any oil?
    Greyish white smoke is usually a sign of oil burning.
    Feb 2012
    Taif Saudi Arabia
    well my car has 145000 kilometers and is looked after well and i am constantly checking for decrease in oil but havent found any and can u please describe to me where the O2 sensors are situated so that i can attempt a clean !!
    Feb 2012
    Taif Saudi Arabia
    and can someone please elaborate where the Petrol Pressure Regulator is Situated in this Engine and how it could be changed ??
    one_and_only2004's Avatar
    one_and_only2004 is offline Turbo L98 FTW
    Z Series Thunder Utility - Turbo
    Mar 2008
    Regional NSW Australia
    Quote Originally Posted by Shakeeb Ahmed View Post
    Fuel regulator is the round thing with the vacuum hose on the fuel rails themselves.
    VZ Thunder - 424RWKW Turbocharged V8 - Parts by AKO Performance
    VY S Series 2
    May 2010
    O2 sensors are situated near the bellhousing on the exhaust manifolds.. you cant clean them you have to get new ones
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    SavVYute's Avatar
    SavVYute is offline Beatus ille
    VY S V6 Ute Series II 2004
    Nov 2009
    Duckburg
    Could you have the spark plug leads crossed over? (mixed up).
    Does the 'check engine' warning light come on?
    Feb 2012
    Taif Saudi Arabia
    well I have completely changed the fuel in the tank and have moved on to high octane 95 well the Plug leads are in order and thanks i have located the O2 sensors the biggest problem here with these Australian cars here are that they are very technical and there parts are also not easily available and any more Ideas on what could be wrong with it
    Feb 2012
    Taif Saudi Arabia
    Quote Originally Posted by one_and_only2004 View Post
    how can we check that the fuel regulator has gone bad or not and is it also called a Diaphragm ??
    Mar 2008
    I think there might be a little diaphragm inside of it, but I don't really know for sure. You could take it off and hit it with about 60psi of pressure through the vacuum reference to see if it opens I guess?
    VY 03
    Aug 2005
    I would be looking at the fuel pressure regulator to start with If there is a tiny crack in the diaphragm it will suck fuel into the manifold Will it only do it on start up?
    VT-VZ max elleries < PM
    VS l67 statesman
    Dec 2008
    aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
  15. #15
    Chevrolet Lumina Coupe S (Monaro CV6)
    Feb 2011
    Abu Dhabi
    Mechanical parts should be easy enough to get hold of in Saudi - I have no trouble here in the UAE. Mechanically it's standard GM stuff, so any decent supplier of US auto parts should be able to get them.
  1. Urgent help needed!! :(
    By miner_richie in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 05-10-2010, 11:10 PM
  2. lumina from saudi arabia
    By black arrow in forum VE - WM
    Last Post: 28-01-2010, 09:52 PM
  3. VS urgent help needed
    By antwillow in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-12-2009, 09:09 AM
  4. Near Saudi Arabia or Bahrain ?
    By BOY1236 in forum The Pub
    Last Post: 29-11-2009, 11:26 PM
  5. urgent help needed!
    By boourns in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-04-2007, 09:56 AM
Tags for this Thread
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
