Results 1 to 12 of 12
Like Tree1Likes
  • 1 Post By ivabiggen
Thread: Question About Wheels On VY
    VT
    Dec 2011
    Default Question About Wheels On VY
    I Just bought a set of 19 inch VE SSV wheels and tyres which I got really cheap, I understand I need to have them machined to fit my vy ute but im wondering if the standard tyres which i believe are 245/40/19 will fit without any issues, the main thing im concerned about is if it changes the speedo reading? Also would there be any rubbing issues or would i need to go down tyre size??
    TMM's Avatar
    TMM
    TMM is offline OEM+
    VY Berlina S2
    Jun 2008
    VIC
    speedo will probably be out about 5ks (reading too low, you'll be going 105 when it says 100)
    Shouldn't rub. Ideally you should have 245/35R19.
    VY II Acclaim
    Jun 2011
    Shellharbour
    I just put a set of 19's on my car last week. I got a set of 245/35/19, haven't noticed any difference in the speedo. The diameter of the whole wheels, including tyres, is pretty much the same as it was when it was stock. Because my 15's had thicker tyres. And there's no issues with rubbing, plenty of clearance. Too much IMO, I'm now looking into lowering.
    DevilDRake's Avatar
    DevilDRake is offline Braaaap
    2013 SV6-Z Manual Ute
    Oct 2009
    S.E VIC
    245/40/19 will hit the front strut tower. You'll need new tyres for the front.
    Speedo will be out about 3-4k's as TMM said.
    Quote Originally Posted by perkoracin
    it like u pull at to a red light and they go o its that fag from just Commodores and it like u go tohe drags and ur car runs a like a 9 sec run as a eg and theres run a low 14 um i would Lol so hard like Epicly and then call them The Internet Mouthers and no go Lol thats a eg they might have Fast as rides 2 but may not sound as a Nice small block chevy with a Supercharger on it lol.
    Click here for my new 2013 SV6-Z Manual Ute!
    VT
    Dec 2011
    If I change all the tyres to 245/35/19 it then shouldnt be out on the speedo?this is just my main concern because I can't afford to lose any more points
    VY II Acclaim
    Jun 2011
    Shellharbour
    You should go 245/35/19 purely because it still leaves clearance above and around the whole wheel. And AFAIK, ur allowed to get away with 10% above the speed limit because speedo's can legally be 10% innaccurate (is that correct?). So having the speedo at most 5 km/h off isn't gonna cause you any grief.
    2003 VY Commodore SS 5.7L M6
    Feb 2012
    Adelaide, SA
    Quote Originally Posted by CJAff View Post
    If you're speeding they'll fine you regardless of how accurate your speedo is. Get hold of a GPS that gives you a speed reading, get on the open road and put cruise on so that it can read accurately and double check how far out you are so you know for sure. Trying to use your speedo as an excuse for speeding will only dig your hole deeper.
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    245/"40"x18 will rub especially on the front struts so sell off the tyres if they are any good and get some 245/"35"x19 and you shouldn't have any problems.
    VT
    Dec 2011
    thanks guys, just gonna get the new tyres and hopefully sell the old ones! and get the speedo calibrated.
    VY II Acclaim
    Jun 2011
    Shellharbour
    Hey, don't know if you're still interested, but i found this tool online:
    Tyre Calculator - Alloy Wheels - Specialist supplier of alloy wheels and tyres packages, Fast Delivery, Buy Online.
    The difference % is what you're looking at, obviously the lower the better. It's also cool that it gives you a rough speed difference estimate
    ivabiggen is offline Banned
    vz Executive
    Aug 2011
    BF BEND
    Quote Originally Posted by nicko92 View Post
    sorry to get off the subject but i'd like to know how can you lose DEMERRITS, points are accrued not lost,please stop perpetrating this URBAN MYTH.
    VY Commodore Equip
    Feb 2012
    Tassie
    This is no longer true , you can be fined for going even 1km/h over the limit and if you try to use the excuse "my speedo must be alittle out" then they can defect your car.
  1. Upgrading wheels question
    By ZaRnOw in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-03-2012, 09:32 AM
  2. VE wheels on Pre Ve , Nuts question lol
    By Trayner in forum General
    Last Post: 29-12-2011, 01:54 PM
  3. Wheels question
    By VS FTW in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-07-2011, 10:17 PM
  4. Mag Wheels Question
    By Gazza2005au in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-05-2010, 11:22 PM
  5. Wheels offset question
    By nilprapai in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-05-2006, 10:32 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
