Results 1 to 4 of 4
Thread: Diff Leak.
    VYII S Utility
    Mar 2012
    Gold Coast
    Default Diff Leak.
    Hi all I have a 04 Vy S Ute with factory LSD and it seems to be leaking abit around the rear diff housing. Just thought I'd see if anone knows if this is an easy job to fix, and if anyone has taken the housing off before and what you had to do etc. Also what LSD diff oil whould be the best for it.
    Cheers.
    2012 VE SV6 series 2 and 911 Porsche 996 3.6
    May 2009
    VIC / NSW
    Quote Originally Posted by Mad Dutchy View Post
    Cheers.
    Click image for larger version.
    I have the same LSD in my car but no leaks so no comment on the leak issue.
    When replacing the diff oil I checked with both Castrol and Penrite and they each recommended only the following fully synthetic products for these diffs:
    1. Castrol: SAF- XA 80w 140 fully synthetic
    2. Penrite: SIN Gear Oil 80 which is also 80w 140 grade fully synthetic
    SIN GEAR OIL 80 - Penrite Oil
    Do NOT use any diff additive with these oils.
    Here is a useful post on changing your diff oil.
    How To: Changing Differential Oil (VZ)
    VYII S Utility
    Mar 2012
    Gold Coast
    Quote Originally Posted by Sean880 View Post
    Cool thanks for that. Yea I'm not sure on the leak It seems to have been sealed with sealant at some stage. And I'm not sure if these are supposed to use a gasket or just sealant. As the sealant could be the main reason for the leak.
    lsx
    lsx is offline
    VT 5.7L M6
    Mar 2012
    NSW
    1.Drain all the oil out
    2.Undo the four 13mm bolts
    3.Undo the rear housing
    4.Clean off the sealant with a razor blade
    5.Re-seal rear housing
    6.bolt it all back together
    7.Fill diff with oil 1.6L I think
LinkBacks (?)
  1. 26-06-2012, 08:31 AM
  1. Commodore diff - hypoid or spiral bevel??? Calling all diff experts.
    By Circlotron in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-03-2012, 09:43 PM
  2. 304 I need a new diff.. well I want a new diff..and mine's noisy..so..I need a new diff.
    By Warranty Void in forum V8 Development and Modification
    Last Post: 24-05-2010, 01:19 PM
  3. Diff leak....Why nowwwww?
    By 1991_Vn2nV in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-01-2008, 11:00 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
