Results 1 to 6 of 6
Thread: V8 cats on V6
    03 VY V6 S2
    Oct 2005
    Default V8 cats on V6
    Hi,
    I have a V6 with Genie extractors and a single cat system. I want to covert it to a dual cat system. I have some cats from a stock ss v8 but not entirely sure if they fit. The genie headers have a 2 1/8 slip fitting.
    Im not exactly sure what size the inlet of the cats are, havent had time to really match it up.. it has the section where the o2 sensor screws in, then a joint and it looks like fatter bit of pipe that went up the the manifolds
    Not_An_Abba_Fan's Avatar
    Not_An_Abba_Fan is online now Exhaust Guru
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    They will fit, but you will have to fit the twin system up first then hold the cats up to see where you need to cut the front section off to meet up with the extractors.
    If by saying you want to fit a twin cat system, you are meaning that you want to fit a V8 style cat back exhaust.
    Visit my Facebook page
    Quote Originally Posted by 191kieran191 View Post
    contact Not an abba fan he is the best
    Nuff said really.
    1999 VTII SENATOR
    YOU BUY!!!
    ALL SERIOUS OFFERS CONSIDERED
    http://www.carsales.com.au/private/d...o=Stock&items=[Make:HSV,Model:SENATOR,Series:VT%20II]&sort=default
    03 VY V6 S2
    Oct 2005
    Yeah ive got whole exhaust. I guess my main concern is whether i can retain the slip fitting or if i need to weld it
    thanks
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Measure the outside diameter of the pipe on the section in front of the weld at the O2 sensor fitting. The bit where that loose flange is sitting in the picture. That will tell you whether or not the pipe will go inside the extractors or not.
    Nuff said really.
    1999 VTII SENATOR
    YOU BUY!!!
    03 VY V6 S2
    Oct 2005
    my next question is if i have a dual catback exhaust replacing a single exhaust, what is the situation with the exhaust hangers? I dont think i have the one for the drivers side...
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Ideally you will need the the hangers on the body for the right hand side, but it will still be OK without it.
    Nuff said really.
    1999 VTII SENATOR
    YOU BUY!!!
  1. Cats for vt v6
    By dagsy in forum XFORCE
    Last Post: 15-03-2012, 01:23 PM
  2. cats
    By Chris1991 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 13-11-2011, 04:56 PM
  3. cats
    By Macka21 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 21-01-2009, 04:14 PM
  4. best cats?
    By vyss300kwute in forum VY Holden Commodore (2002 - 2004)
    Last Post: 21-12-2008, 02:41 PM
  5. The Four Cats
    By bazcom in forum Jokes/Humour
    Last Post: 03-11-2007, 06:56 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
