georgeyboy
hi guys,
i drive a 2004 vy commodore S. My driver door window is playing up!!
It will go up and down but stops about 2cm from the top, so will not close all the way. When it reaches that
point I hear a gear crunching sound coming from the door. Could possibly be slipping the teeth in the gears.
The power does not cut out until I let go of the switch. its not allowing the relay switch to kick in.
I have pulled door trim off and it looks a bit tricky to get my hands in there. Cut the plastic at the openings
to have a look inside, cant really see anything worth noting.
ive had a mate tell me (without seeing the car) that possibly the last few teeth on gear arm that lifts the
window could be broken off.
if i manually pull the window up for that last 2cm, it then closes fully and stays up.
any advice???
cheers
any advice???
cheers
