Results 1 to 23 of 23
Thread: VY Ute air vents
    vy_storm's Avatar
    vy_storm is offline just another moderator...
    VE Calais V 6L
    May 2005
    the burbs of Adelaide
    Default VY Ute air vents
    Made an observation the other day with the interior ventilation on my ute and was wondering if anyone else has had any revelations.
    I have always noticed the cup holders in the centre console had been quite cool to the touch when the a/c was running. I had assumed that this was because the venting channel to where the vents would be in the sedan still run through. I also assumed that this would have been blocked up to prevent a pressure loss through the other vents.
    Much to my amazement i stuck my hand up under the passenger side next to the auto shifter and I could feel air gushing out of the side of it. It looks as though mine is not plugged up at all.
    So, was wondering if anyone else has observed this? as I wouldn't mind getting a bit more air pressure out of the vents in the dash after finding a way to plug up the stray outlet in the console.
    I managed to pull up the console piece with the cup holders and window switches to get a look at it this afternoon, but it appears that it might need a bit more trim to be taken out to get full access to the air outlet. It might be that when I have had my headunit and phone handsfree installed that they have dislodged something, but I doubt it.
    Any ideas people????
    Jun 2005
    perhaps its holdens method of keeping your drinks cool?
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    vy_storm's Avatar
    VE Calais V 6L
    May 2005
    Quote Originally Posted by stocky
    Or hot..... I wouldn't put it to Holden to be that clever anyway.
    HBD VYII Acclaim
    Nov 2005
    Perth, WA
    Default External flutes
    Speaking of vents... let's take a wander to the exterior of the vehicle. Has anyone ever done a mod to the Guard Flutes (that replace the side indicators) to actually act as an exhaust vent? This would have been the logical thing to do to start with, but heah...
    INACTIVE ACCOUNT. No longer monitored.
    vy_storm's Avatar
    VE Calais V 6L
    May 2005
    Quote Originally Posted by vy_acclaim
    I heard they serve no purpose to exhaust at all........
    HBD VYII Acclaim
    Nov 2005
    Perth, WA
    Quote Originally Posted by ardseidel
    They don't - they're purely aesthetic. Could have been a real feature for a little effort on Holden's part - shame.
    Barcode is offline lllllllllllllllll
    May 2005
    i have a vz and same deal-has air coming out back of the console
    would like to know if this is just because holden could not be bothered to change for the ute or if it serves some other purpose
    i find it just blows cold air straight towards the cabin vents which seems a waste
    Holden_Mechanic Guest
    if its under warranty and u think it mite be a prob, take it to City Holden. we do a gr8 job with warranty. but just remember. our labour prices r a little steeper if it turns out not to be warranty. it is a dash out job. and our trim expert will take great care of your car
    Quote Originally Posted by vystorm_adel
    vy_storm's Avatar
    VE Calais V 6L
    May 2005
    Quote Originally Posted by Holden_Mechanic
    To be honest, if another warranty issue comes up it will go back to my local dealer (Metro Holden) otherwise i will get around to shoving a sock (or something else handy) in the vent. It's just not worth me taking time off work to drop off/pick up over such a trivial issue at the moment. Have already had the damn thing back under warranty twice in the 6 months i have had it :b:
    VE2 SV6 SPORTWAGON
    Feb 2006
    SA
    mine has no problem, but the interior in the ute gets too cold and i have to turn it off frequently, that probably where climate control comes in handy
    ok obviosly if ur happy wit ya local dealer, (Metro) why change.
    what other warranty probs have you had if i may ask?
    vy_storm's Avatar
    VE Calais V 6L
    May 2005
    To date i've had it back for:
    1. The squealing/scraping rear brakes, where they fitted the 'handbrake adjustment kit'.
    2. A water leak onto the front left passenger floor that couldn't be traced but ended out stinking out the cabin with the damp carpet for a few days. It hasn't appeared since.
    3. Peeling/flaking paint/coating on the left rear quarter window rubber which they replaced the whole window and rubber (minus the tint). Will post some pics of this later in the probs with VY's thread in case any one else has had the same dramas. I know it used to be bad on the VS window rubbers, but I would have thought that it had been cured by now.
    All relatively minor issues but annoying none the less.
    Chich2 is offline chich2
    VZ SSZ Ute 5.7
    Dec 2005
    Babinda Far North QLD
    Firstly - G'day to everyone as I am a first time Forum User.
    I have a new VZ SSZ ute which I've just installed a new sound system into. While I had the console pulled to bits I saw that the air vent under the console does end on the left hand side beside the gear shifter. It has 2 screws that seure it to the console at it's end. I left mine open as there is a electrical controll box of some sort right at the back of the console attached to the top of the floor arch that I thought may need some sort of air flow. Plus I am real happy with the airflow through the vents as is. The thing nearly blows ya hair out.
    As for waranty jobs, when the vehicle was 450Km's old the pasanger side exterior plastic trim that runs up the roof FEL OFF!
    While I was installing the sound system I found LOTS of water sitting under the driver side carpet where ya feet go. There are some threads just on this matter.
    The ute is in for it's 3000K service at the moment so I'll find out what the outcome is this arvo.
    vy_storm's Avatar
    VE Calais V 6L
    May 2005
    Be interesting to see what you find out about the water. From what I was told, the front end of my car was soaked/drowned to see if there was a leak and they found nothing, and it hasn't happened since. Might have just been a blockage in the AC drainage, who knows....
  15. #15
    clixanup is offline Has Left
    Jan 2004
    How could you make this work without damaging the structural integrity of the front end? And how much benefit would such vents provide in the real world?
    Have a look under the bonnet of a VZ SS, taking note of the locations of the strut towers, brake booster and powertrain control module and then explain to me how Holden could've possibly undertaken such an exercise without going to great lengths for no apparent benefit...
    But back to the original topic - If your car was a sedan, I'd say that it sounds like the pipe which supplies air to the rear ventilation outlets has been dislodged. But you have a ute, so maybe the plugs which block the outlets for the rear have fallen out or something. Should be an easy fix, either way.
  16. #16
    HBD VYII Acclaim
    Nov 2005
    Perth, WA
    Quote Originally Posted by clixanup
    ...How could you make this work without damaging the structural integrity of the front end? And how much benefit would such vents provide in the real world? explain to me how Holden could've possibly undertaken such an exercise without going to great lengths for no apparent benefit...
    Installing the vents dosn't diminish the structural integrity of the panel... I'm not a mechanical engineer, so could not comment on the effect that ducting would have on the structural integrity of the chassis; but I'm sure that if such an enhancement could have been made cost effectively, then it would have. I assumed that by having two external exhausts and two external intakes (bonnet and radiator grille), that the engine could be cooled more effectively... granted a great deal of ducting, etc would probably be needed, but would have been awesome none the less. I come from a computer enthusiast background, where the elimination of heat was of high priority. No doubt this line of thought has stayed with me, as I am constantly looking for ways to cool anything that generates heat... lol. I just feel like the vents were an after thought - an aesthetic enhancement. Had the vents been incorporated into the initial design, I don't see why they couldn't have been a functional component...
  17. #17
    Jan 2004
    Remove the plastic insert inside the wheel arch and have a good long look under there. Then come back and tell me that the quarter panel vents could have been made functional.
    The point is that at speed (when the vents would be working) there is sufficient airflow from the front and underneath of the car to cool the exhaust. The side vents would contribute nothing at all to the cooling of anything.
    As far as cooling goes, a car is nothing like a computer. It moves through the air, and is designed to take advantage of the cooling benefits this motion provides. If they just sat still like a computer case, I'd agree with you 100%, but they don't.
  18. #18
    HBD VYII Acclaim
    Nov 2005
    Perth, WA
    ...Remove the plastic insert inside the wheel arch and have a good long look under there...
    I'll take your word for it. I was just floating an idea to see if anyone had this area; obviously not - so it's all good.
  19. #19
    Ute 04 VYIISS 5.7 M6
    Jan 2006
    Newman, WA
    Took the dash apart today, found the vent/pipe that leads nowhere.
    So I just taped it up, no more extra cool console.
  20. #20
    vy_storm's Avatar
    VE Calais V 6L
    May 2005
  21. #21
    SPack's Avatar
    SPack is offline Wish it would rain......
    VE MY10 SV6 sportwagon (phantom)
    Sep 2005
    Oakey, QLD
    LOL........ Another great half-arsed design with no thought for the customer. Well done again Holden!!!
    Here's a new sales pitch...
    'Buy a new Holden ute,......... looks great, goes like a rocket and comes with a free pair of socks (stuffed in the console).'
  22. #22
    VYSSion Guest
    I also have the air blowing under the centre console, but don't really want to fix it. I find it very hard to believe that Holden did this "accidentally". I would think that the ute has the same aircon and fan system as the sedans, so they didn't want to increase the standard pressure that comes out of the main vents. I think the pressure coming out is already excellent, any more would freeze!!
  23. #23
    vy_storm's Avatar
    VE Calais V 6L
    May 2005
    Honestly, I wouldn't put anything past Holden these days. If you think about it though blocking it off would be no different to the vents facing the rear seats being closed and not being used.
  1. S to SS vents 06'
    By VZ-Rob in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 03-09-2006, 01:36 AM
  2. vents under airbox
    By Matt_vp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-04-2006, 09:17 PM
  3. Air Vents
    By wooly72 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-12-2005, 03:49 PM
  4. vents
    By justbad4you in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-10-2005, 01:33 AM
  5. Air con vents for 97 VSII
    By Leece in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-10-2005, 09:39 PM
