VY Running Very Rough!!
jewie
41
adelaide
VY commodore executive s1
Im after some advice on what to check as i have changed my leads and spark plugs on Saturday, and the car was running fine.
Today i decided to replace the conduit that the leads sat in and now i have done it the car has been running really rough.
I checked out my dash and its reading 99.9 litres per 100ks...
I have tried the old set of leads and plugs with no difference...
Is there any vaccuum lines i may have knocked or anything else you guys could think of??
Trevor 062
60
St Clair
2012 VE S2 SSV REDLINE & 07 VZ ACCLAIM WAGON
Probably one of the coil packs has **** itself
lowandslow
NSW
V2 III Monaro
Didn't crack a plug by accident?
Try removing one lead at a time whilst the car is running. The one that doesn't make a difference will be your problem.
greenacc
Searching for the billion
VE Berlina
Did you unplug anything else while doing this and forget to put it back on ? There are plenty of plugs and vacuum hoses around there you could have disturbed, and if you moved the alternator check around that too.
SavVYute
VY S V6 Ute Series II 2004
Reconnected one of the leads to the wrong spark plug?
jewie
41
adelaide
I took the car to get a scan. Turned out its a cracked egr pipe from where i recently had the valley cover gaskets changed..
