Results 1 to 12 of 12
Thread: Parcel shelf speakers??
    VY Executive
    Nov 2005
    Default Parcel shelf speakers??
    Hey Guys,
    My VY Exec doesn't have parcel shelf speakers standard, however I am wondering if the wiring for these is likely to be in place as I believe the higher spec models have these speakers standard.
    Also, does this mean the head unit has 6 channels or are the rear channels split?
    brentmc's Avatar
    brentmc is offline Custom: Better than stock
    VYS S1
    May 2005
    The Calais make use of the parcel shelf and offer a 6 speaker setup. (4 door speakers + 2 parcel speakers). Because the headunit is only low output its feeding about 12 and a half watts per channel so while I'm not entirely sure, I don't think the parcel speakers would be split with the rear door speakers as this would distort the system over such a low output. I'm pretty sure the head unit has outputs for 6 speakers (3 of the same stereo channels that is...ie - front, back, boot).
    But having said that, unfortunatly the wiring isn't already there on the "lesser" models...
    VY Executive
    Nov 2005
    Hmmm, ok so no wiring. Not such a big problem. Can anyone else confirm or disprove this 6 channel theory. It sounds like a long shot to me but I must wonder how the 6 speaker setup is wired if it doesn't have 6 channels.
    If there are in fact 6 channels in the Calais, does the Exec have the same headunit or is it different?
    VY Executive S2
    Dec 2005
    There is no wiring in the parcel shelf area have just punched out the spot welded dummy plates and removed the sound deading material.
    Also brought a pair of VT/VX speaker grilles for my VY ser2 for $47 @
    Autobarn so im getting closer to buying some 6X9s and installing myself.
    Not sure how much to spend or the brand/wattage either.
    Regards
    Fred
    HBD VYII Acclaim
    Nov 2005
    Perth, WA
    There are only 4 channels on the Blaupunkt stereo (RR,RF,LF,LR). I got that from the top of the actual headunit. As for the speaker arrangements - the parcel shelf speakers are spliced with the rear door speakers as standard. You will need either a power amp, or too disregard the rear door speakers if you want full power on the parcel speakers...
    INACTIVE ACCOUNT. No longer monitored.
    VY Executive
    Nov 2005
    brentmc's Avatar
    VYS S1
    May 2005
    Hm, thats why I originally said that over such a low output it would be silly to splice them like that. Wow, so if you have parcel speakers fitted by holden then really your worse off as the rear of your car is sharing about 25w among 4 speakers...
    ...and people still defend this stock setup...?
    vy equipe S11
    Jan 2006
    Brisbane,QLD.
    Fred,I've done what you're doing,i've put JBL gto936e 300 watt 6x9's in the parcel shelf and replaced the origional front door speakers with pioneer tsc1625's 220 watts.I'm piggy backing the 6x9's off the rear door speaker wires with my own wiring set up (spade double adaptor male and female terminals that splits one wire into two) that can easilly be disconected if you want to take the 6x9's out later if you sell your car.Of course,make sure connections are taped so they don't touch each other.I've been running this set up with the origional 6 stacker head unit with no amps at 3/4 volume with no problems.
    Tim
    vzlumina's Avatar
    vzlumina is offline 01/05 VZ Lumina AKW-989
    '05 VZ Lumina, '99 CR125
    Aug 2008
    Is the standard speaker setup not sick, doors, and then the two tweeters in the dash?
    Phreddy's Avatar
    Phreddy is offline Bye SV6 - still love you
    VS-II Statey-8
    Apr 2005
    W-Sydney NSW
    Yes, vzlumina has it. It refers to "six speakers,", that's one in each door, plus the two tweeters in the corners of the dash. The upmarket "premium" system has additional "subwoofers" (if you can refer to 6" cones as subwoofers) driven by an external amp mounted in the boot. (it's about 40w or something)
    And for anyone who's serious, the stock Blau can be made to perform a whole lot better - RCA outputs and amps brings them to life. That's not defending the stock setup though, not at all - it's not powerful enough, and the factory speakers are absolute rubbish. As they still are in the VEs..... As for being able to keep the stock appearance and functionality and still get quality sound though, it can be done.
    Demos welcome!
    New look ASR Website online now!!
    www.asr-audio.com.au
    Interior lighting and audio specialties
    for VT/VX & VY/VZ Commodore / Monaro
    NOW VE DASH LIGHTING CONVERSIONS!!
    PLUS TECH2 DIAGNOSTIC SERVICES
    JBL Car Audio dealer
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    Quote Originally Posted by Phreddy View Post
    Demos welcome!
    Can you please confirm for me.
    Does the OEM Blaupunkt head unit have provisions for RCA cables that can be attached to an amp?
    Forgive me I'm a total Audio newb, but I do like to hear it as best I can.
    If a simple amp will give the boost that I'm looking for I'd be happy.
    trentvy's Avatar
    trentvy is offline Dodges raindrops
    Vy S pack
    May 2008
    Kilsyth South
    the stock blaupunkt head unit doesnt have rca outputs, theres a bloke on the forums called 'phreddy' who is pretty clever and he modifys them to have rca outs. PM him if your interested.
  1. vt calias parcel shelf speakers not working
    By monsoon in forum Car Audio
    Last Post: 21-03-2007, 07:28 AM
  2. VX rear speakers in parcel shelf
    By vyaw2003 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-01-2006, 03:59 PM
  3. Parcel Shelf Speakers for VTII
    By scbh81 in forum Car Audio
    Last Post: 30-11-2005, 05:15 AM
  4. Speakers in rear parcel shelf
    By Pompeygaz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-01-2005, 04:41 AM
  5. Removing VN Berlina Front Parcel Shelf Speakers
    By anton1o in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-01-2005, 06:57 PM
