VY Engine Error Codes
Aggro_VE
The Overseer
Lake Macquarie
A lazy VE
Try this mate..
Turn the ignition off
Press and hold the trip computer UP and DOWN arrow buttons
Turn the ignition on while holding the buttons
After approximately 3 seconds, release the buttons.
The service menu appears with a reset request.
Press and hold the SET button for more than 3 seconds.
Press the MODE button
And to get into the other functions, hold Mode and Set while you turn ignition on, then hit Mode to go thru the functions till you reach Trouble codes with alot of zero's, thats what you want and that's all you want :).
S
sickvy
Guest
I have looked at the error codes and found that it looks something like this:
0000000000000
1000000000000
Don't no exactly how many zeros on a line but it has a 1 at the start of the second line. Wat does this mean? It used to be all zeros...
Doctor Bob
Grandpa
Retired
RG. Colorado & Caravan
the Vy has no provision to flash engine codes on the dash, the trouble codes you have there are the instruments only, you need to plug a tech2 in at a dealer to check codes on these.
Cheers Rob
Aggro_VE
The Overseer
Lake Macquarie
A lazy VE
Do what the Doctor orders, and call him in the morning :)
davleigh
Vx SS Commodore
What does that code mean though?
Sent from my LG-P875 using Tapatalk
VY2016
Newcastle
VY S-Pac Commodore
Hey mate, i know this is an old thread but what was the problem?
Mine started idleing rough as yesty and stalled itself, when i went to the trouble codes it was the same code.
