Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By Nut Kracker
Thread: VY Engine Error Codes
    VH Wagon SLX 253
    Nov 2004
    Southern Highlands
    Default VY Engine Error Codes
    Does anyone know how to reset the service reminder in VYs, and also how to bring up engine error codes? i assumed it was the same trick as VTs but it doesnt appear to work?
    Aggro_VE's Avatar
    Aggro_VE is offline The Overseer
    A lazy VE
    May 2005
    Lake Macquarie
    Try this mate..
    Turn the ignition off
    Press and hold the trip computer UP and DOWN arrow buttons
    Turn the ignition on while holding the buttons
    After approximately 3 seconds, release the buttons.
    The service menu appears with a reset request.
    Press and hold the SET button for more than 3 seconds.
    Press the MODE button
    And to get into the other functions, hold Mode and Set while you turn ignition on, then hit Mode to go thru the functions till you reach Trouble codes with alot of zero's, thats what you want and that's all you want .
    Seriously, I'm trying to see things from your point of view but I can't get my head that far up my arse!!
    sickvy Guest
    I have looked at the error codes and found that it looks something like this:
    0000000000000
    1000000000000
    Don't no exactly how many zeros on a line but it has a 1 at the start of the second line. Wat does this mean? It used to be all zeros...
    Doctor Bob's Avatar
    Doctor Bob is offline Grandpa
    VT V6 Exec & VN V6 Exec
    May 2004
    Mornington Peninsula
    the Vy has no provision to flash engine codes on the dash, the trouble codes you have there are the instruments only, you need to plug a tech2 in at a dealer to check codes on these.
    Cheers Rob
    Aggro_VE's Avatar
    A lazy VE
    May 2005
    Lake Macquarie
    Do what the Doctor orders, and call him in the morning
    Vx SS Commodore
    Feb 2012
    Nut Kracker's Avatar
    Nut Kracker is offline (Nucifrangibulum)
    VT SS 304ci (195i) 2011 Cruze SRi-V 1.4L Turbo
    Oct 2012
    Echuca Vic.
    Quote Originally Posted by davleigh View Post
    What does that code mean though?
    Sent from my LG-P875 using Tapatalk
    Click below for my
  1. error codes
    By Nobody Actually in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-09-2008, 09:37 AM
  2. VT Error Codes.. HOW????
    By stheggie in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-01-2007, 01:56 PM
  3. Error codes Help please
    By WiLo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-06-2006, 08:09 PM
  4. v6 ERROR CODES
    By cuckoo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-07-2005, 04:52 PM
  5. Error Codes on my VS SS V8 Help!
    By Ravager in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-08-2004, 10:15 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97
