Results 1 to 9 of 9
Thread: Common (unknown) Seat Fault with VY - check yours
    VY Equipe Guest
    Default Common (unknown) Seat Fault with VY - check yours
    I have heard from a friend that Vy's have a comon fault where the seat frame comes through the side of the seat. If you look down where the hand brake is, you may see that the side of your seat is torn/ split. Sure enough when i had a look at mine it was there (very pissed) going to call holden on monday!
    VY Exec S2
    Sep 2005
    HBD VYII Acclaim
    Nov 2005
    Perth, WA
    Yeah!! I have it on mine too - thought that my fat a### blew out the seat! HAHAHA. Off to get it fixed courtesy of GM now!
    INACTIVE ACCOUNT. No longer monitored.
    Morgasshk is offline Morgasshk
    VY Exec 3.8L Sedan 9C1 Pack
    Aug 2005
    good luck...
    holden refuses to replace an upholstery type damage/wear on my car... bastards...
    VY Equipe Guest
    there is no way this could be wear, its down the side where the hand brake is. There is no way i would have ever had my body any where there if it wasnt for being told about it.
    VY Equipe Guest
    I posted the same comment on another forum and got the following reply......... so its worth kicking up a stink
    Yes I had the same problem but on the opposite side
    of the seat and I put it into Holden and they replaced the cover and all the
    seat cushion no questions asked. I feel there is a problem which Holden are
    keeping to themselves about. Good Luck
    B£å¢kÐðg's Avatar
    B£å¢kÐðg is offline D.I.L.L.I.G.A.F
    VY Commodore
    Oct 2005
    Had me worried there for a sec but checked mine and all is good
    "Some say that he only knows 2 facts about ducks...and they are both wrong".
    Every K Over Is A Thriller
    vy executive
    Mar 2006
    Bacchus Marsh
    just checked my vy and both drivers and passengers seamed to be ripped I will have a good look tommorow when its light
    ve ssv ute
    Feb 2006
    I just had mine for a service recently, and it actually had a faulty spring in the drivers seat would u believe it, holden fixed it under warranty but i only noticed anything when i looked at the service sheet it said the job had been done there ... i have no idea how that can fail but it did. Weird or what?! what do you reckon happened there?
  1. Check power train light - common problems???
    By exec57l in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-09-2007, 06:47 PM
  2. Get a new battery, or electrician to check for fault?
    By jim898 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-01-2006, 11:45 AM
  3. How to check fault codes (VP)
    By CLE in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-09-2005, 06:13 PM
  4. Valley Gaskets - common fault ???
    By dontsailbackwards in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-05-2005, 01:21 PM
  5. Common Vl Fault
    By Garth in forum Electrical Wiring / Questions
    Last Post: 04-12-2003, 02:14 PM
