+ Reply to Thread
Results 1 to 7 of 7
Thread: park light globe missing????
    hbdvysute is offline Utes the word hbdvysute Executive
    vy s ute
    Apr 2006
    Default park light globe missing????
    well i was changing the parker lights in my car today mind u the most unsual method ive ever seen, and i was having trouble placeing the driver side parker light loom thign back into the light, as i took the parker light back ut to see wat was goin on the globe was missing!!! its stuck in side the tear drop, has anyone any ideas on how to remove the globe or is it stuck there till the light has to be pulled apart???
    VYII SS UTE
    Feb 2006
    Dont pull the light apart, take it out, face the opening down and shake, or just leave it in there.
    vy s ute
    Apr 2006
    doesnt taking the light off require the front bar to be removed, its just wat i have heard, if this is the case, that globe has found a new home
    VYII SS UTE
    Feb 2006
    some say its easier to take the bar of than just the grill and try to get under,
    Yeah if its not affecting anything just leave it there and don't worry about it
    HBD VYII Acclaim
    Nov 2005
    Perth, WA
    Tried using a magnet? You can buy telescopic magnets for next to nothing...
    INACTIVE ACCOUNT. No longer monitored.
    JA SV8 Guest
    this happened to me!! it was the biggest pain.
    I got one of those long things with like claws on the end and pulled it out that way, it worked, took a bit of effort and cut hands though....
    I think i got the tool from a car shop, or hardware shop. Its one of those things you use to get small screws outta small spots.
    Hope this helps
    James
    SPack's Avatar
    SPack is offline Wish it would rain...... SPack Executive
    VE MY10 SV6 sportwagon (phantom)
    Sep 2005
    Oakey, QLD
    I had this happen to me also. I ended up removing the light assy to get it out. No need to remove bumper but the grill had to come out. It was a bit tricky but worked ok. To get the bulb out I used a long screwdriver with some bluetack on the end. You MUST make sure the bluetack is secure on the end of the screwdriver or it will end up lost with the bulb; fold it down the shaft a bit and wrap some tape around it. Don't make the bluetack too big or it will won't come out through the hole. Fiddly bloody job. Stupid design I rekon.
+ Reply to Thread
  1. LED Brake - T/Light globe problem
    By CANYONERO in forum Electrical Wiring / Questions
    Last Post: 14-03-2007, 06:30 PM
  2. Million dollar light globe
    By Pub247 in forum The Pub
    Last Post: 01-08-2006, 05:54 PM
  3. Park Light Shorting
    By Cody in forum Electrical Wiring / Questions
    Last Post: 14-05-2006, 01:29 PM
  4. Tail Light Instalation and globe replacment
    By Torquen in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-04-2006, 11:37 PM
  5. Park Brake light stays on?
    By sk1p in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-01-2005, 02:43 PM
