sorry for the wait, finally got around to sorting through a pile of paperwork today and found the codes list that I got from holden awhile ago for my car.
The codes are as follows:
80U - EXTERIOR PAINT COLOUR, PHANTOM MICA
81D - INTERIOR TRIM CLOTH, ANTHRACITE
81I - INTERIOR TRIM, ANTHRACITE
A32 - WINDOW POWER OPERATED, FRONT DOOR
AH6 - ADJUSTER FRONT SEAT POWER, 4 WAY, VERTICAL, DRIVER
AK5 - RESTRAINT SYSTEM SEAT, INFLATABLE, DRIVER & PASSENGER
AQ9 - SEAT FRONT BUCKET, DRIVER & PASSENGER RECLINING
AX2 - KEY COMMON, VEHICULAR UNIQUE
B3Y - FLEET ORDER
C60 - AIR CONDITIONING FRONT, MANUAL CONTROLS
D75 - HANDLE OUTSIDE, DOOR, BODY COLOUR
DP5 - MIRROR OUTSIDE BLACK
FE2 - SUSPENSION SYSTEM RIDE, HANDLING
G80 - AXLE POSITRACTION LIMITED SLIP (LSD)
GU4 - AXLE REAR 3.07/3.08 RATIO
JL9 - BRAKE SYSTEM POWER, FRONT & REAR DISC, ANTILOCK, FRONT & REAR WHEEL
LN3 - ENGINE V6, 3.8L, MFI, NORMALLY ASPIRATED
M35 - TRANSMISSION MANUAL 5 SPEED, GETRAG 76MM 3.83 1 SEAT, 0.81 5TH
N40 - STEERING POWER, NON-VARIABLE RATIO
N46 - STEERING WHEEL 4 SPOKES
PDE - SALES ITEM NO.122 - 8VK 35-69 - 1WB
PG1 - WHEEL 15 X 6, STEEL
QAH - TYRE P205/65R15-95H BW R/PE ST TL ALS
RHD - RIGHT HAND DRIVE VEHICLE
U1C - RADIO AM/FM STEREO, SEEK/SCAN, CD, CLOCK, ETR
U4F - FLOOR REVISIONS - FROM 01/01/2003
U4W - NCAP CHANGES AT 'VY'
U75 - ANTENNA POWER, RADIO (FULL UP/DOWN)
UJ8 - CLUSTER INSTRUMENT, COOL TEMPERATURE, TACHOMETER, FUEL, SPEEDO, DOOR, INFO CENTRE
V7E - 2003 MODEL YEAR
VA1 - RADIATOR STANDARD
W1Y - STEERING WHEEL RADIO REMOTE CONTROL
WD4 - IDENTIFICATION EFFECTIVE POINT CONTROL - (MY03) FROM 3L100014
XW6 - PAINT FINISH METALLIC
(MODS, Could this be made a sticky so users can add codes, and maybe it can be sorted in code order, as they get added.)
Thanks Holdensupporter2005
You can ask your holden dealer for a printout of all the option extras codes for your car. They will usually do it for free if you ask nicely
