Register - Members List - Calendar - Mark Forums Read -
Go Back   Just Commodores > Holden Commodore Related > VY Holden Commodore (2002 - 2004)
VY Holden Commodore (2002 - 2004) Talk about anything relating to the VY Holden Commodore.
Reply
LinkBack Thread Tools Display Modes
  #1
Old 21-06-2006, 04:51 PM
fruity's Avatar
Ride: 2003 vy executive
Trade Rating: (0)
fruity Executive
Default Door actuator......Need Help URGENTLY!!!!!
My drivers side door wont open either by remote or key the button goes up half way and down as if its locked. l rang up a Holden Dealer and was told it would cost $154.00 labour ,$110 for the Door Actuator, and $145.00 for a New Door Trim as they might have to break it to get the door open.Is this true or can l do it myself ? Unfortunately my warranty ran out 3 months ago If l can do it myself can someone tell me how ? Thanks
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Google Bookmark this Post!Yahoo Bookmark this Post!Bookmark to AskJeeves!Bookmark to Slashdot!Live Bookmark this Post!Spurl this Post!Reddit! Wong this Post!
Sponsored Links
  #2
Old 21-06-2006, 05:17 PM
evil_monkey's Avatar
Ride: 03 VY 25th Anniversary,83 HJ60 Landcruiser Sahara
Trade Rating: (0)
evil_monkey Executive
hrrmm i think they are yanking your chain as far as the door trim breaking off when i had my vt i had to take the trim off because i was having trouble with my central locking and i think the vt/vy/vz trim is the easiest to get off the trim is mainly screwed on and then held tightly in place by a bracket type thing in the middle of the trim you need to pull it upwards as for the mechanism there not not be anything wrong with it at all myne was doing the same it was just sticking fiddled around with the rods put in a bit of dry lube and central locking was as good as new but if worst comes to worst and you need a new one it should just mount via 3 bolts on the side
  #3
Old 21-06-2006, 05:48 PM
naf33n's Avatar
go
Ride: vz sv6 M6
Trade Rating: (0)
naf33n Berlina
depends if you can get the door open or not. if you cant you more then likely need a new door trim
  #4
Old 21-06-2006, 07:20 PM
fruity's Avatar
Trade Rating: (0)
fruity Executive
Thanks for the advice guys , the door wont open so l think l might have to jusst cop it sweet . l dont know if the earlier commodores have the same door set up or not E_M but l'll try to get it off first before l take it to a dealer. Once again .......Thanks
  #5
Old 21-06-2006, 08:20 PM
Trade Rating: (0)
door trims are exacly same in vt/vx/vy/vz
as for opening the door pull the lock up manually, as i said they can stick sometimes you might not even need to pull the trim off if you pull the lock up manually and push it down again a couple times
  #6
Old 21-06-2006, 09:48 PM
Doctor Bob's Avatar
Grandpa
Ride: VT V6 Exec & VN V6 Exec
Trade Rating: (0)
Doctor Bob MalooDoctor Bob Maloo
yep bang the snib up and down violently, most of the time this frees up the lock to open up the door, i have a brand new rhf lock assembly, (not just the actuator) here for a VY, yours for $100 including postage if you want it
cheers Rob
  #7
Old 22-06-2006, 07:06 AM
Ride: Wanna bee SS
Trade Rating: (0)
Jeffro74 Executive
it is impossible to take a vy door trim off when the door wont open without damaging it,all you have to do is open the other side door up and youll see where the screws are and youll know there is no hope.
  #8
Old 23-06-2006, 11:15 PM
VY Calais
Ride: Silver VY Calais
Trade Rating: (0)
Vanna Executive
I had exactly the same problem, the only way I could open my door was to use the key with my right hand and at the same time using my left hand to push down and lift the lock lever on the inside. You need the window open for this.
Just muck around with it a few times checking if the door opens between every try. Just do the same actions simultaneously and you should notice on the correct go that the lock lever on the inside will come up a little higher... then you got it!!!
Pain in the ass but...
Got the actuator replaced under warranty.
  #9
Old 24-06-2006, 08:04 PM
fruity's Avatar
Trade Rating: (0)
fruity Executive
Thanks all ...........while stationery at the lights l tried to open the door and it works ok now. The cars still going in for the 45000 service so do l get it replaced or has it fixed itself? Thanks
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Thread Thread Starter Forum Replies Last Post
wtb urgently vq door side stripping white vn ss Swap / Wanted to Buy / Trade 1 25-02-2007 09:27 PM
Door actuator - help!! dbates VY Holden Commodore (2002 - 2004) 5 02-12-2006 01:29 PM
replace door actuator Graham Adams VR - VS Holden Commodore (1993 - 1997) 0 27-06-2006 02:58 PM
Central Locking Actuator vpwgn VR - VS Holden Commodore (1993 - 1997) 2 04-04-2005 06:21 PM
Door Lock Actuator micko VT - VX Holden Commodore (1997 - 2002) 0 20-04-2004 05:37 PM
Skateboarding | Mobile Phones | Mortgage Calculator | Bankruptcy Certification | Debt Consolidation | Car Reviews
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
