does anyone know how to remove glovebox assembly to gain access to behind glovebox.........and also how to remove instrument surround...(what else besides two top screws ??)...thanks....
Open the glovebox as far as it'll go. You'll then see a rubber stopper thing on each side of the glove box lid, which stops it opening too far. Just sorta squash each rubber stopper so that the glovebox lid will open past where it's supposed to. It'll just lift out after that.
Hope that made sense, it's hard to describe in writing, but it's real easy.
Not sure what you mean by instument surround??
The rubber stops actually slide up and off their mounts, the glovebox then drops down and unclips.
The instrument surround only has the two screws at the top. Remove them and gently ease the surround out, top end first.
pull hard
hehehehehe
