to do it, which i am about to start, you will need the 4 regulators, front and rear window switches and the BCM(if you wanna go that way). As for the wiring looms good luck cause my series one does not have any wiring in it at all, you do do one of two things, buy the full wiring harness or make it yourself. with the website that cobra30(thanks for that) it should be pretty straight forward to hook up to the BCM and switches. i am about to put them into my car so ill let you know how it goes.
