Register - Members List - Calendar - Mark Forums Read -
Go Back   Just Commodores > Holden Commodore Related > VY Holden Commodore (2002 - 2004)
VY Holden Commodore (2002 - 2004) Talk about anything relating to the VY Holden Commodore.
Reply
LinkBack Thread Tools Display Modes
  #1
Old 22-10-2006, 06:22 AM
Ride: VY acclaim wagon
VYWORKWAGON Executive
Default VY Wagon Towbar
G'day.
Can Anyone tell me if the towbar to suit a VT Wagon will also fit a VYWagon. I have bought one on ebay that was advertised for VT, VX, VY Wagon but after checking with Holden they said the part number on the one I have bought suits a VT and has a different part number to the one they list for my VY. Has anyone that has fitted one have any tips they would pass on about installation(assuming it fits)
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Google Bookmark this Post!Yahoo Bookmark this Post!Bookmark to AskJeeves!Bookmark to Slashdot!Live Bookmark this Post!Spurl this Post!Reddit! Wong this Post!
Sponsored Links
  #2
Old 22-10-2006, 09:45 AM
WAGON MAN's Avatar
Gas Sleeper
Ride: VX S2 Berlina Wagon
Trade Rating: (0)
WAGON MAN Berlina
The towbar for the VT - VZ wagons are the same.
All individual models VT,VX,VY,VZ will have different part numbers.
I have a VX II wagon with a VT wagon towbar ( as fitted by Holden Dealer ).
How many kg's is your towbar rated at ?
Have you purchased a wiring harness ?
__________________
I like my roo well done
  #3
Old 22-10-2006, 11:12 AM
Default VY Towbar
Thanks,
The towbar is rated 1200kg. No I haven't purchased the wiring harness yet though my local Holden dealer has them and apparently there are plugs behind one of the tail lights to simply plug it in though I haven't checked that yet.
Thanks for the info and will go ahead now and attempt the fitting. It appears i have to remove the "rib" behind the plastic outer bumper to get it to fit.
  #4
Old 22-10-2006, 11:45 AM
WAGON MAN's Avatar
Gas Sleeper
Trade Rating: (0)
WAGON MAN Berlina
I'm not too sure if you can install the towbar without removing the rear bumper.
You will find if you remove the bumper (a few screws) it will make it much easier to install the towbar as well as removing the "rib".
The Holden wiring harness is simply plug and play, and is plugged into the main harness at the driverside rear tail light.
Good luck
__________________
  #5
Old 22-10-2006, 04:46 PM
WAGON MAN's Avatar
Gas Sleeper
Trade Rating: (0)
WAGON MAN Berlina
VYWORKWAGON here is a wiring harness for you.
__________________
  #6
Old 22-10-2006, 05:31 PM
Prepare for MV 09!
Ride: TT Supra/HZ Ute.
Trade Rating: (0)
253@7k Executive
It'll fit but if its for a vt it wont look so good. the vt towbars came out from underneath the bumper where as the vy ones came out of the bumper cut out.
To fit: remove bumper: screws in wheel arch, clips on top and underneath the bumper, pop sides out then take off.
remove intrusion bar: 4 x 17mm head bolts.
remove intrusion bar mounts: 4 x 3/4 head nuts.
remove: 2 x 15mm head nuts from fixed bolts underneath car.
fit bar up, i think you refit the intrusion bar on the genuine ones.
run your wiring: colours if you need them (wire behind rhs panel in boot)
(park/brown) goes to brown
(left/yellow) goes to light blue (small plug in seperate harness)
(right/green) goes to dark blue
(stop/red) goes to blue-red
(earth/white) goes to black-blue
Then just put your bumper back and bolt your tongue on.
Easy as.
  #7
Old 26-10-2006, 02:06 AM
thanxs Wagon Man and Slundy
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Thread Thread Starter Forum Replies Last Post
towbar to wagon harry3 VL Holden Commodore (1986 - 1988) 6 21-04-2007 09:39 AM
VT to VZ sedan wagon towbar Berlina wagon Parts For Sale 0 26-02-2007 02:22 PM
VN Wagon towbar fitting thespirit VN - VP Holden Commodore (1988 - 1993) 3 11-09-2006 05:21 PM
towbar. wagon and ute bisonlee VN - VP Holden Commodore (1988 - 1993) 1 04-05-2006 06:50 PM
VX towbar, will a ute towbar fit a wagon??? Phrog VT - VX Holden Commodore (1997 - 2002) 1 08-01-2006 03:31 PM
CreditCards | Debt Consolidation | Mortgage | Loans | Loans | Car Reviews
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
