Nope.
To remove bumper (sedan) remove 3 srews from each side in wheel arch (6 if mudgards fitted)
Remove 2 clips from underneath.
Peel back crarpet inside boot and remove 2 10mm nuts each side.
Remove bumper by pulling sides out (use force) and once poped out slide off backwards.
Undo bolts holding towbar on and refit intrusion bar.
Refit bumper putting cut out back into bumper (should be in the boot of your car)
Easy as.
