Register - Members List - Calendar - Mark Forums Read -
Go Back   Just Commodores > Holden Commodore Related > VY Holden Commodore (2002 - 2004)
VY Holden Commodore (2002 - 2004) Talk about anything relating to the VY Holden Commodore.
Reply
LinkBack Thread Tools Display Modes
  #1
Old 18-11-2006, 11:24 PM
Ride: VY ACCLAIM
Trade Rating: (0)
race4life Executive
Default squeaking noise from the engine
Hi Everyone,
My vy acclaim has been nothing but problems lately .. i have started hearing a squeaking noise from somewhere in the engine. it becomes particularly loud if its rev'd over 2500 rpm . its also quite audible when idling or when the car has been started after a while. What is wrong? I didnt use my car for a couple of months when I was overseas and have been back for about a month now... didnt seem to have this problem even after i came back. I just realized that its happening this afternoon . Does anyone know what it is? I dont want to take it to a mechanic unless its something major. Any help majorly appreciated.
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Google Bookmark this Post!Yahoo Bookmark this Post!Bookmark to AskJeeves!Bookmark to Slashdot!Live Bookmark this Post!Spurl this Post!Reddit! Wong this Post!
Sponsored Links
  #2
Old 19-11-2006, 10:08 PM
Ride: VY Exec S2
Trade Rating: (0)
maxy0987 Berlina
serpentine belt? I had a similar sort of problem and the just tightened the belt (adjusted the tension pulley) and its all fine.
I didnt notice it louder er or softer at different revs though, i could only hear it when i was idle and outside my car (in the driveway for example)
  #3
Old 19-11-2006, 11:34 PM
Ride: VY ACCLAIM
Trade Rating: (0)
race4life Executive
Thanks for the info mate. how do i tighten whatever belt it is!!! Can you give me some instructions on how to do the above ? its frustrating to crank up your car and hear shit coming out of it.
  #4
Old 20-11-2006, 12:15 PM
genetic_freak's Avatar
Technical Geek
Ride: VR berlina 304
Trade Rating: (0)
genetic_freak Executive
being a vy v6 you cannot tighten the belt, the tensioner does that automatically. now from memory their is 2 main possibilities.
1. the power steering pump pulley is out of alignment (quite common) this causes the belt to squeak as it is rubbing sat an angle over the pullies.
2. you have a worn idler pulley. a great way of checking is to have a long screwdriver and you put it on the nut of the corresponding tensioner whilst the engine is running (making sure it is a stationary nut or else it could get messy ) and then listening on the other end of the screwdriver. you will be able to hear which idler is blown cause it will sound like a dry bearing/ screeching noise.
__________________
Its a common miss conception that people actually use their brains before they speak.
  #5
Old 20-11-2006, 09:11 PM
Ride: VY ACCLAIM
Trade Rating: (0)
race4life Executive
Angry power steering f'ed
yep.. took it to the mechanic i get the car serviced by and he said that the power steering pump is almost f'ed and that it was good that i got there in time. Its a pain in the arse . There goes another $450 beggin.
  #6
Old 20-11-2006, 09:17 PM
Peanuts Inc.'s Avatar
Ride: 355 VG :)
Trade Rating: (0)
Peanuts Inc. MonaroPeanuts Inc. Monaro
did he tell you wht was actually wrong with it??? cos really the only thing that should be wrong with it is the front or real seal being only a few years old??? havent seen many other problems with them
  #7
Old 21-11-2006, 08:35 PM
Utes the word
Ride: vy s ute
hbdvysute Executive
hey mate, i had the same problem but only on start up when the engine was cold, i was told it was the water pump pulley, idler pullleys ended up being the starter motor.. so 3 new pulleys later and a new starter motor problem resolved
  #8
Old 22-11-2006, 12:43 PM
Ride: VY ACCLAIM
Trade Rating: (0)
race4life Executive
the culprit was actually the clamp which holds the power steering pump in place.. the problem has been repaired and has made my pocket lighter by about $170 . bloody stupid thing..
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Squeaking noise emmiting when weather is wet jesterofseven VR - VS Holden Commodore (1993 - 1997) 11 12-11-2007 11:32 AM
squeaking noise in air con. Northern_Union Airconditioning (all models) 9 06-09-2007 05:16 PM
Squeaking noise from wheels. sim_vs VR - VS Holden Commodore (1993 - 1997) 6 19-12-2006 08:07 PM
squeaking noise coming from rear axle ciaranvt VT - VX Holden Commodore (1997 - 2002) 3 25-08-2006 12:56 PM
Squeaking noise on left hand side majobe VR - VS Holden Commodore (1993 - 1997) 10 21-02-2005 06:37 PM
Tax | Debt Consolidation | Credit Counseling | Secured Loans | Names | Car Reviews
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
