Page 1 of 2 12 LastLast
Results 1 to 25 of 38
Thread: completed aftermarket head deck install
    VY Series 2 SS
    Oct 2006
    brisbane
    Default completed aftermarket head deck install
    Finally got around to getting an amp wiring kit and just wondering where people have put the wire through there firewall and where they run it to the boot?
    Pictures would be awesome, cheers guys
    Lumps of cheese's Avatar
    Lumps of cheese is offline Who wants chowder?
    MY08.5 VE V8 CALAIS/2010 Hilux SR D4 Dual cab 4x4
    Boulder Crusher Champion! Balloon Park Champion! Action Fish Champion! 501 Darts Champion! Frogger Champion! Jungle Kid Champion!
    Nov 2005
    Warrnambool
    I'm not far away from doing my vy, but done a mates not long ago.
    I went thru on drivers side up top, there is wires going thru there but be careful not to damage the other wires.
    I ran the power cable under the plastic door trims next to the drivers and back seats, very quick and easy, you can also pull the back seat out in 2 mins to get the wire thru to the boot, makes a neater job of it.
    That's how i did it anyways...
    davey g-force's Avatar
    davey g-force is offline I'm a sceptic...
    Phantom MY09 VE SSV A6 & Holden Cruze CDX M5
    Sep 2005
    "...the winner is..."
    I went through the firewall on the passengers side. There is a black rubber grommet where other cables are running through. I just poked a tiny hole through the grommet and shoved the amp power wire through it.
    Like juzsvy, I ran the wire under the plastic of the door sills. Mine only had to go to under the passenger seat though, so I've got no tips on running it to the boot...
    Quote Originally Posted by CSP (aka Rufys) View Post
    Look, all the update is going to be is like going from VX to VY or VY to VZ. Same car with different front/rear ends and updated interior. But it will be the VF, not the VE II.
    Oct 2006
    Strathfield did mine yesterday... through the firewall on the drivers side and under the moldings down the drivers side and up behind the back seat..
    vp calais
    May 2006
    adelaide
    clutch hole in the fire wall if its auto or find another suitable hole u can feed it through. then again run the power and remote wire for the amp under the drivers side plastic scuff plates, under the rar seat to the boot. then run the rcas down the passenger side to avoid alternator wine. then mount ur amp were u want it make the earth as short as possible for best ground clean the grounding point thoroughly so its bare metal on bare metal, then wire it up and turn it on.
    VY Commodore Series 2 Exec
    Nov 2006
    Hey, was thinking about replacing the stereo in my vy s2 exec, was wondering on how to go about it eg head-unit, amp etc do it professionally or myself? Any help would be great thanks
    holdensupporter2005's Avatar
    holdensupporter2005 is offline Donating Member
    VE SV6 Commodore - Silver
    Sep 2005
    N.E. Vic
    if it is a manual, unfortunately there is no spare holes and you will need to drill a hole in the firewall yourself. (I had an autoelectrician do it for me.)
    http://forums.justcommodores.com.au/signaturepics/sigpic17276_1.gif
    CHECK OUT MY RIDE
    IF I WAS HELPFUL TOO YOU CLICK MY SCALES
    "Girls are like domain names, all the good ones are taken."
    Nov 2006
    I was looking to upgrade my stereo, with head-units how do i go about replacing them, can i use any or does it have to be double din? If not what do i put in that space? Thanks
    Nov 2005
    Warrnambool
    Quote Originally Posted by batch_0695 View Post
    I'm guessing you have a single disc player?
    If you have a 6 disc player you can get a mod of phreddy, run a search and you'll find him.
    You can replace the deck with single din, i think they make a mould that fits straight into your dash to take up the space, has a pocket in it from memory.
    I've seen these for sale at autobarn.
    Nov 2006
    Default VY Stereo Upgrade
    Has any one done this or have any good advice on how to go about this? I did the stereo on my old car but this is a little harder and could stuff something up lol
    VY Series 2 SS
    Oct 2006
    brisbane
    Nov 2006
    What did you do to yours? I havent really had a look at mine properly but the main things were the head-deck, did you have any problems or things i might have trouble with? What did you use to fill the hole? What did you do about the factory speakers? Thanks
    VY Series 2 SS
    Oct 2006
    brisbane
    I have a VY series 2 SS this is what i bought and it sounds beautiful.
    -Aerpro ISO to bare wire plugs, allows you to use the existing wiring without cutting anything
    -Aerpro in fill panel to cover the hole up
    -Aerpro aerial adapter so you can plug it into the aftermarket deck deck
    -Grilles for the back of parcel tray
    -Wiring kit
    Thats what you need to get it so you can put all the aftermarket stuff in
    What i have in the car is:
    Alpine CDA-9857 head deck
    Alpine 6*9 speakers in the parcel tray
    Alpine MRP-F450 4 channel amp
    im using the standard door speakers and it sounds amazing
    Its not easy took me a day to do because i stuffing around ALOT i was originally gonna keep head OEM head deck but didnt want to cut wires to get the speaker to RCA converter installed.
    The way i have dont mine i can take the aftermarket head deck out and put the OEM one back in and everything works as normal its great.
    if you have any questions ask me and if you want the part number of any of that aerpro stuff just ask and ill find it.
    Also everyting i used came from northfield they are excellant and not up them self wankers like people from JB and the like
    Nov 2006
    How does that iso to bare plug thing work? Does it look ok? like does the headdeck look out of place? What grilles do you mean, couldnt you just use the ones you get with the 6x9's? Thanks
  15. #15
    VY Series 2 SS
    Oct 2006
    brisbane
    here are some photos. In regards to the plug i used it plugs straight into the socket that the OEM head deck plugs into and the other end has bare wires to wire up your aftermarket head unit - very good way of doing it as you can put the OEM head deck back without cutting any wires. The grilles i bought look alot better than the ones that come with the speakers as it looks like a standard calais the way they are.
    Attached Thumbnails Attached Thumbnails completed aftermarket head deck install-pc030434.jpg   completed aftermarket head deck install-speaker-grilles.jpg
  16. #16
    VY Series 2 SS
    Oct 2006
    brisbane
    here are some more photos of my install. any questions feel free to ask
    Attached Thumbnails Attached Thumbnails completed aftermarket head deck install-pc020435.jpg   completed aftermarket head deck install-pc020436.jpg
  17. #17
    Nov 2006
    That makes it look hard lol How do the factory speakers sound? I was thinking about going down to strathfield or somewhere and getting them to install the head-deck and amp, that way i dont stuff anything up and then install the subs myself and keep the factory speakers for the moment, what do you think? Was it easy to install the 6x9's? And do you know what size/shape the door speakers are? Thanks
  18. #18
    VY Series 2 SS
    Oct 2006
    brisbane
    its not hard at all as long as you have an idea of what your doing.
    Im actually very happy with the way my install turned out didnt destroy anything on the car except the holes i made in the parcel tray for the 6*9's.
    The factory speakers are actually pretty good i can turn they up really loud and they dont distort its great. I will probably put better ones in eventually as the ones in the parcel tray that are amplified can go alot louder than the OEM ones. I dont know what the OEM speakers look like or what size they are maybe post a topic in the audio section. Im after a device so i can use my steering wheel controls to operate the head deck, jsut have to find someone in australia that sells this one:
    http://www.pac-audio.com/products/pr...el%20Interface
  19. #19
    Nov 2006
    Oh ok, i have a good idea of what im doing, its just i dont want to stuff anything up, can you ground an amp to the baby seat latch thing in the boot? Do you know if any of the big companies like supercheap, autobarn etc stock the fascia thing?
  20. #20
    VY Series 2 SS
    Oct 2006
    brisbane
    I grounded my amp by drilling a self tapping screw into the car body near my amp you can do that or just put it onto a bolt thats close baby seat latch will do as the bolt goes into the body.
    I bough the fascia from a place called wow sight and sound in brisbane, but autobarn can get it in for you its a Aerpro product product code 'FP9045' to suit VY monaro/commdore. - its very easy to install. If you have any questions when your doing it PM me ill be happy to help you.
  21. #21
    Nov 2006
    If i did it myself i would probably order the head-deck and amp off ebay coz its fairly cheap, does autobarn also have the connector and aerial thing? What does the aerial thing do?
  22. #22
    VY Series 2 SS
    Oct 2006
    brisbane
    yeah autobarn will sell it part number for the Aerpro aerial adapter is AP349 and the plug you want is APP7201. Note that the plug is made for european vehicle head decks, but i can assure you it is the correct one do not go off the aerpro website its not correct i made that mistake the first time.
    The reason is that blaupunkt the manufacture of the OEM head deck is german, hence the reason why you need the aerial adapter as the aerial plug is european.
  23. #23
    Nov 2006
    What did those 3 cost roughly? Have you or anyone had any bad experiences buying off ebay? Was it easy to install the 6x9's?
  24. #24
    VY Series 2 SS
    Oct 2006
    brisbane
    the aerial thing cost $9 fascia $27 and wiring plug thing $19. 6*9 easy to install screwed them straight to the body, cut out the holes in the parcel shelf thing put the grilles and all done. its not a hard process if you understand what to do before you start. so understand what you have to do before you start it.
  25. #25
    Sep 2005
    ...do you know what size/shape the door speakers are?
    The factory door speakers are 6 inch, 5 Watt, paper cone, made in Korea jobs. They are really quite crappy. You can replace them with better 6" speakers or you can even get 6.5 inch speakers in there with a little cutting/filing.
    As for getting Strathfield or the like to do the install - *cringe*
LinkBacks (?)
  1. 10-09-2011, 04:12 PM
  2. 22-10-2010, 12:14 PM
  3. 29-12-2009, 01:18 PM
  4. 16-05-2009, 01:11 PM
  5. 15-12-2008, 05:10 PM
  6. 14-12-2008, 11:18 AM
  7. 30-08-2008, 06:37 AM
  8. 29-08-2008, 12:18 PM
  1. got my clarion head deck
    By cxcxcxvcvcvc in forum Car Audio
    Last Post: 10-12-2007, 10:00 PM
  2. vs aftermarket guage install
    By westoz in forum General
    Last Post: 11-09-2007, 09:37 PM
  3. good head deck for 700 bucks????
    By belave in forum Car Audio
    Last Post: 25-04-2007, 06:10 PM
  4. '96 VS Exec S2 aftermarket Alarm Install
    By nick88 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-04-2006, 11:19 PM
  5. how to install new deck
    By VSIIBerlinaL67 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-06-2005, 01:10 PM
