Results 1 to 18 of 18
Thread: Has Anyone Got A Shift Kit In A Vy?
    VY S1 S-03
    Apr 2006
    Question Has Anyone Got A Shift Kit In A Vy?
    Hi guys i want to know if anyone has a shift kit in their VY? Im am considering a stage 2 shift kit for my car? any idea's or any opinions i will take
    thanks guys
    VYII SV8
    Aug 2006
    Toowoomba
    What do you mean by "shift kit"? Do you mean a short-throw shifter for a manual gearbox, or perhaps a device for making an auto gearbox change gears in a more aggressive manner?
    If you want to change an auto gearbox's manner of operation, I understand this will soon be possible with the use of VCM Suite software - this means you can have your normal shift behaviour in ECON mode, and much more aggresive shifts in POWER mode. I would strongly recommend this modification rather than modifiying the mechanicals of your gearbox.
    03 VY V6 Ute
    Jun 2006
    perth
    whens that becoming available???
    i contemplated a shift kit, didnt interest me much, but if it was just a computer mod rather than mechanical, id go for it
    davey g-force's Avatar
    davey g-force is offline I'm a sceptic...
    Phantom MY09 VE SSV A6 & Holden Cruze CDX M5
    Sep 2005
    "...the winner is..."
    It's already available for the Gen III as part of the edit tune. Not sure about V6's...
    Quote Originally Posted by CSP (aka Rufys) View Post
    Look, all the update is going to be is like going from VX to VY or VY to VZ. Same car with different front/rear ends and updated interior. But it will be the VF, not the VE II.
    VY Acclaim Wagon
    Jan 2007
    i did this a couple years ago in my ef falcon. 10 bucks it cost. I just put a switch in my dash which turned it on and off, it had a couple of resitors between the gear box and the computer. Worked well but 2 years later the drive train was stuffed so think about it first, it puts a lot more stress on parts of ur car that aren't made for it
    VY S1 S-03
    Apr 2006
    Default sounds oryt
    is what im after, my car is automatic, how would i change something in the computer? im confused, would it work out better?
    walesy's Avatar
    walesy is offline Aint no family cruiser!!!
    Cherry Black WH II Caprice, VS exec wagon
    Jun 2005
    Perth SOR
    go to a trans shop they will sort it out for you there was a thread on here about them and most people said they were about 250-300 bucks...
    have no idea what jrod done to his falc for 10 bucks!!?? get it cubed??
    Going where no late model stato/caprice has gone before.... GAME ON!!
    VY Acclaim Wagon
    Jan 2007
    the same thing as the one that cost a couple hundred bucks but i did it myself, just had to do a bit of soldering. And yes it changed gears a lot harder, the wheels would chirp when it changed from first to second when i went flat out. If u do get it, make sure you've got a switch to turn it off. shift kit + wet roads = sideways car
    vt1538's Avatar
    vt1538 is offline 455rwhp LS3
    VY SS S2 11.284@125mph
    Sep 2005
    The Dead Centre
    Quote Originally Posted by Egnitevt View Post
    The pcm in your car controls the engine & the transmission. All the shift points, shift times & line pressures can be changed in this manner plus a variety of other settings. This is the recommended way of tweaking your tranny, not some snake oil type fix that can do more harm than good.
    VYII SV8
    Aug 2006
    Toowoomba
    I may have jumped the gun a little....tuning the shift points etc is available on the V8 models (I've had it done, and it's great) and I understand that VCM Suite will soon be able to tune the Alloytech computers, but I'm not sure this will be available for VY 6-cylinder models as they use a totally different computer. Perhaps Kalmaker or similar can mess with these settings?
    Using electronic means to alter shift behavior is far preferable to mechanical mods such as the ones mentioned above because it can be easily fine-tuned to give you precisely the response you are after. It also give you the optionof returning to stock (or a milder setting) at the touch of the Power button. No need for compromise - choose your shifts to suit your mood.
    chappy's Avatar
    chappy is offline VY2 R8 Clubsport
    VY2 R8 Clubsport
    Apr 2005
    North Queensland
    thanks guys
    If you want all the good oil and pro's and con's of the Transgo Shift Kit stage 2 try talking to Peter on 07-46391264 what he carn't tell you isnt; worth knowing.
    Its worth the phone call trust me.
    In the beginning God took 5 day to create Holden, on the 6th day he created HSV and the 7th day he refined his work to create the R8 Clubsport.
    http://www.hsv-holden.com.au
    Kai2tae's Avatar
    Kai2tae is offline 02kittedvy
    vy berlina a4
    Feb 2006
    thanks guys
    I've got the stage II shift kit in my v6 vy and it's good as, 1st to 2nd's much quicker and harder but not so hard it chirps,just a nice sitting feeling...slight difference in all the gear changes but the 1st to 2nd's the most noticeable
    dagar187's Avatar
    dagar187 is offline ls1nder
    VZ-SS
    Dec 2006
    nsw
    peter at vcm told me they wuld have a program for the alloytech in 3 weeks so id ask him if he can help out ur vy?
    VYII Spac S/C
    Sep 2005
    Not sure which shift kit company you guys are talking about, but what are these guys, more importantly thier products, like?
    http://www.shiftkits.com.au/Default.aspx
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Now if the poll was 'Would you let someone else root your missus' then the answer would be different. That would depend on what their missus looked like and if you could root them.
  15. #15
    VY S1 S-03
    Apr 2006
  16. #16
    The Windsurfing VY Wagon's Avatar
    The Windsurfing VY Wagon is offline Donating Member
    VY S2 04 S/W
    Oct 2006
    Cairns, QLD
    Hi there,
    I just put in a single stage shift kit in my Acclaim SII.
    After putting it in I took her for a test run and after a few runs I started picking up the difference between on & off.
    She clicks in from first to second super quick and with a bit more pow, not a thump.
    It even feels like second to third is quicker but I gather I only have a single stage as that's what www.shiftkits.com.au reccomended on there website for the V6 so I bought it.
    Cost me $85.00 inc freight and it was piss easy to fit.
    At the end of the day I didn't need one but there cheap and easy to fit plus since you can turn it on or off is great so when I am in the mood to play I can switch her on and off I go....
    Hope this helps
    Windsurfing.....
    This is what you call a real sports wagon, BOUY!!!
  17. #17
    Kai2tae's Avatar
    vy berlina a4
    Feb 2006
    Bump;; anyone got a shift kit installed in a VYv6 yet?
    Yeah man, had it for awhile now and all good...
  18. #18
    VYII Spac S/C
    Sep 2005
    Thanks guys, im sold. Was weighing up between this or a B&M shift kit, but I really prefer the idea of electric over mechanical.
  1. Shift Kit for VR Ute
    By FREESTYLE_MX in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-10-2008, 08:19 PM
  2. Shift Kit?
    By fitzy2005 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-11-2006, 08:11 AM
  3. sub and shift
    By ducatis in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-10-2006, 07:49 PM
  4. Shift Kit
    By Cootie in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-05-2006, 05:59 PM
  5. Shift kit
    By cuckoo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-02-2005, 10:10 PM
