Page 1 of 4 1234 LastLast
Results 1 to 10 of 31
Thread: Power Steering Noise
    VYII SS Ute 5.7 M6
    Jun 2004
    Default Power Steering Noise
    Just wanting to know if anyone else has experienced Power Steering problems.
    Mine is making a strange whining noise on low speed, under 20km/h turns. It doesn't matter if it's hot/cold, in/out of gear, air conditioning on/off. It's not the typical air in the fluid noise...
    To me it sounds like high pressure fluid being pushed through the rack, a sit only happens when the steering wheel is being moved...
    It's not overly loud, but at an annoying level that you hear an know something is not right...
    Strangely Holden can't replicate it... The workshop manager came for a drive with me, and heard it, proclaiming he thought it was the rack... But then they couldn't replicate it on the hoist...
    VY II SS
    Jun 2005
    Yep ive got the same noise, just an irritating whine while you move the wheel around at low speed. Ive got a VY SS II, ive noticed fluid level going down a bit as well. I need to take it to holden to get it fixed
    Not_An_Abba_Fan's Avatar
    Prado
    Aug 2006
    Bunbury, WA
    Could be crap in the fluid creating a restriction in the line somewhere. Or a dodgy valve in the rack.
    VYII SS Ute 5.7 M6
    Jun 2004
    Yep irritating is the word.
    I'm not losing fluid at all though.
    I've had it at Holden, at the 10, 20, 30, & 40 service but they couldn't find it... On returning for post-service warranty work, I took the workshop guy for a test drive around the car park and he said straight away it would be the rack and would change out the rack.... "Quite common" apparently... But Hey they didn't change out the rack, but simply lubricated the "steering column"... Which didn't do a bloody thing...
    It's now going back in for post-post-service warranty work and service rectification work, with the hope of "finding" what the problem is...
    I'd be happy with them doing a fluid flush through the system... I've had the discussion with the service manager who said that wouldn't be covered under warranty.. My standpoint... Holden Service manual doesn't make any recommendations about service intervals for the power steering fluid, hence it's not a consumable as such... Same as differential oil... If there is something wrong with it in the warranty period, Holden should cover it, otherwise make a recommedation in the service schedule in terms of flushing the system!!
    I'll let you know how I go tomorrow with the works!
    vy series 2 v8 berlina
    Dec 2006
    Gday guys, Holden know about this problem and have a modification to fix it, they replace your power steering lines with larger diameter hoses to reduce the pressure in the system.
    VS Acclaim SII
    Nov 2006
    Yep I get the same noise aswell. A Particular whine especially when turning right. I also noticed if I have the hood up you can hear a slight air sucking noise aswell. Very irritating
    Being Insane Keeps You Sane
    VYII SS Ute 5.7 M6
    Jun 2004
    Well Guys, I had the car in on Friday for the power steering work, and other stuff. This time around the workshop and service manager took it for a drive to listen. They are still scrathing their heads though. They did a high pressure flush on the system hoping that it will stop the noise in the short term. Unfortuneately it hasn't though! They said that it could be the seal at the top of the rack and if necesary will replace that, but can't guarantee that it will fix the problem...
    ve 2 sv6 sport wagon
    Feb 2008
    hi guys, i have a vy with 35,000kms like new, the power steering pump makes a whirry noise goes up and down with revs there are no leaks fluid level is spot on. I took the belt off and the noise was gone i have checked all pulleys there fine, i have heard this noise on vr and vs any ideas on how to fix it just annoying.
    VT Berlina & mazda 2 DE
    Jul 2006
    Similar noise here, flushed the system and used a decent, power steering specific fluid. No real noise any more.
    VYII SS Ute 5.7 M6
    Jun 2004
    Well the latest was the pump and rack were replaced!
    Holden replaced the rack after I pushed and pushed for it, but only to fail to bleed the system properly, which then had me back for another trip to get the pump replaced under warranty!
  1. oil line from power steering to steering rack
    By onmy6 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-12-2007, 09:08 AM
  2. VH Power Steering..Trade For Manual Steering
    By vasrox in forum Swap / Wanted to Buy / Trade
    Last Post: 28-01-2007, 01:29 PM
  3. power steering noise???
    By lilkel in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-05-2005, 05:36 PM
  4. power steering noise
    By dungbeetle46 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-04-2005, 08:47 PM
  5. Power Steering Noise
    By vn_calais in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-02-2005, 06:57 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97
