G'day All
I've got a VY series 2 auto, want to buy those HSV alloy pedals (They are smooth) from ebay
Just wondering how hard it is to install them? Can I do it by myself or requires an expert...
Will appreciate your response
looks like the pedals on ebay have a template to show you where to drill the holes so should be easy as pie!
Not sure about the HSV model, but the VY SS pedals were relatively simple. No holes drilled although clutch and brake needed a good lever with a screwdriver to lift the lip over the pedal.
The go pedal was the slowest part, as the hinge pin needs to be removed and I found the easiest way to do it was by taking the throttle assembly out of the car. It was slow but not real hard to do.
