There was a recall on the fuel pump sender units or MRA . VX-VY
To remove the pump the tank must be removed .
It take around 2 hour to remove and replace the MRA
Glad im not paying your labour bill.
three bolts on the straps holding the tank in place, remove fuel cap, remove hoses.
drop tank gently tap the top of the fuel tank where the pump is remove carefully undo hoses, and clips, remove pump, install new pump conect it up put back in tank, connect hoses put tank in place do up 3 bolts.
hour tops, just make sure that you have about 1/4 of a tank in it for balast.
