Phreddy, I've removed the shifter surround (where the shifter boot gets held in) without removing the console. I've attached a pic of how far I got..can you get at the globes from here, or do you need to remove more stuff?
I've circled the 4 clip locations in red for cpbait's benefit - you can use a long screwdriver or butter knife to undo the clips. It's a bit awkward but it can be done.
cpbait i have replaced mine about three times but they keep blowing all you have to is remove the the side panel on the console.just pull the plastic plate down then you can get to the bottom of the shifter there are two wires going under the shifter its a bit tight . But put two fingers in turn the globe anti clockwise from memory then pull the plug and globe out the globe is a T10. Iput a led globe in then put the globe and holder back under the shifter its a bit fiddly push it back up and turn. then put ur trim back up and push to its back into positionjust want some help please with removeing the trims to get the auto shift light globe out, does anyone have a discription or pictures of what needs to be removed, cheers, Ben.
