Results 1 to 3 of 3
Thread: supercharged thermostat replacement
    Mar 2007
    Unhappy supercharged thermostat replacement
    I have just completed the thermostat replacement on my sons supercharged V6 I was thinking it would be a 20 minute job, big mistake, 2 hours later all done. Armed with the parts thermostat & seal, thermo gasket, throttle body gasket & rear manifold gasket. I found that you don't have to remove the rear manifold as advised with the throttle body and the vacuum servo and rear cover bracket the housing is accessible the rear bolt with a short 10mm spanner, on refilling the coolant pay particular attention to bleeding from the three bleed screws the thermostat bleed screw is particularly difficult to access behind the vacuum servo so loosen before assembly. Not too difficult once you commit yourself to doing it.
    I hope this has been helpful to some of you.
    Joe
    Lumps of cheese's Avatar
    Lumps of cheese is offline Grumpy old ####
    MY08.5 VE V8 CALAIS/2010 Hilux SR D4 Dual cab 4x4
    501 Darts Champion! Action Fish Champion! Balloon Park Champion! Boulder Crusher Champion! Frogger Champion! Grrr... Game Champion! Jungle Kid Champion!
    Nov 2005
    Warrnambool
    08 VE SS-V 6.0Lt V8 SEDAN
    Mar 2006
    Yeah I did a Thermostat Change on my VY S/C and it was a lot harder than I thought. The Ecotecs are so easy.
    Took me a while to undo the Bolts (A slow gradual process), but eventually got there.
    Gotta a cooler t/s and now she is great.
  1. Thermostat on a supercharged 6
    By Scooter79 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-04-2013, 08:49 PM
  2. thermostat
    By homer simpson in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-10-2007, 05:31 PM
  3. thermostat
    By slayer in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-10-2006, 09:48 PM
  4. Thermostat Replacement
    By Darren in forum VY Holden Commodore (2002 - 2004)
    Last Post: 29-11-2005, 07:50 AM
  5. thermostat
    By danz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-09-2005, 07:52 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93
