Results 1 to 8 of 8
Thread: Boost Gauge
    VY, S supercharged 2003
    Dec 2006
    Default Boost Gauge
    Hi guys. Just wondering if anybody has put up a boost gauge in a Commodore supercharger V6?
    If yes, please let me know eactly where to hook the boost hose up to? Will appreciate it.
    Thanks.
    VYII Spac S/C
    Sep 2005
    There ya go And as for a way to get it through the firewall, I found a rubber gromet on the passenger side about an inch in diameter. It's not used for anything (guessing for LHD conversions). Disconnect your battery, remove the top of the dash and the two console sections (upper and lower), then remove the side vent on the passenger side (the one that is hidden when the door shuts). I used a thin rod of metal to "thread" the boost line under the airbag area all the way over to the center of the dash. If you want some better instructions on feeding the line in and all, let me know and i'll write up a proper how to.
    Last piece of advice, make sure before you cut the line (vac/fuel regulator from memory) that you have a t-piece that will fit, I didnt do this, and almost bodged the whole damn installation! All fixed now though
    http://forums.justcommodores.com.au/...d.php?p=490624
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Now if the poll was 'Would you let someone else root your missus' then the answer would be different. That would depend on what their missus looked like and if you could root them.
    ford
    May 2005
    in a ford
    underneath the snout of your supercharger there is a black plug, take it off & run the the vacuum line to this, i did it with mine & get an accurate reading, i can take a photo of the location if you want
    Dec 2006
    Quote Originally Posted by Charg'd (sexy vn chick lover) View Post
    Thanks buddy. I would really appreciate it if you could get me some pics. Please buddy.........
    Dec 2006
    Quote Originally Posted by krazyboris View Post
    Thanks buddy.
    ford
    May 2005
    in a ford
    Dec 2006
    ford
    May 2005
    in a ford
    here you go, you attach the vacuum pipe to the silver piece you see in pic under the snout, it will be covered by a black plug, be warned that when you take the plug off it might crumble in your hands ive circled the the vacuum point
  1. boost gauge
    By vs_commodore_s in forum VL Holden Commodore (1986 - 1988)
    Last Post: 06-10-2007, 01:18 PM
  2. boost gauge
    By 10000_fists in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-05-2007, 03:29 PM
  3. Boost Gauge
    By XU6 (fLOGINU) in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-01-2006, 06:40 PM
  4. Connecting boost gauge to VS
    By VSSleeper in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-09-2005, 02:26 AM
  5. Wtb:- Boost Gauge
    By V6VL in forum Swap / Wanted to Buy / Trade
    Last Post: 06-05-2005, 02:22 PM
