Results 1 to 13 of 13
Thread: Vents change up hill
    Mar 2007
    Default Vents change up hill
    I have a VY Berlina. When I go up hill the air vents change from face to screen. It seems like a vacuum issue but all the hoses are connected. Any ideas?
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    ive seen it once at work, i think it was the hot air mix flap actuator leaking.... so it could be one of the actuators in the system...theres 6 or 7 from memory
    davey g-force's Avatar
    davey g-force is offline I'm a sceptic...
    Phantom MY09 VE SSV A6 & Holden Cruze CDX M5
    Sep 2005
    "...the winner is..."
    I've seen this one covered before here somewhere, so it must be fairly common. I can't remember the outcome though. Have you tried doing a search?
    Quote Originally Posted by CSP (aka Rufys) View Post
    Look, all the update is going to be is like going from VX to VY or VY to VZ. Same car with different front/rear ends and updated interior. But it will be the VF, not the VE II.
    VY Series 2 SS
    Oct 2006
    brisbane
    it is normal took mine to holden they said its normal, got something to do with the vaccuum cant get enough pressure or something to keep the vent open so it opens the default vent which is the windscreen one.
    Sep 2005
    Quote Originally Posted by ris00 View Post
    Hmmm, that sounds like a Holden dealer cop-out to me...
    Maybe they're right, but I'd be looking into it more.
    2004 VY2 SV8 A4
    Jun 2005
    Victoria Point, Brisbane
    I know its not VS but all the climate control systems up to VS and probably onward have an issue where occasionally when going uphill the vents change from face to floor, and return to face when you get off the throttle.
    My understanding is that this is normal because of the way the vents are controlled. I am guessing its because under those engine conditions, there is not enough vacuum being stored in the vacuum ball to maintain adequate pressure at the air vent servos, and they return to their default positions until the engine conditions change and the vacuum comes back.
    * Phreddy's Blaupunkt Aux input and line out mod
    * 18x8 inch Equus Kalibur Wheels with Maxxis MAV-1 235/40R18
    * Sureflo 3.5 inch medium-loud cat back exhaust
    VT V8 Calais
    Mar 2007
    I have the same issue in my VT. I did have this issue in my falc and there was a vacuum hose connector that had come loose. I just can't find the same sort of thing in the commie
    bugger
    50LTRv8
    Series II Monaro CV8 Redhot
    Mar 2005
    Perth, WA
    The problem will most likely be the one way vacuum check valve (it is black and white) in the engine bay near the firewall.
    MY 8.5 Calais V 6.0L, 88 VL Calais Turbo
    Jan 2006
    i have same problem, found the vacuum tank under the passenger airbag and its too small to hold enough vacuum for the system (design fault) im putting another larger canister under the bonnet to increase capacity, hopefully that will help.
    03 VY EQUIPE
    Apr 2010
    I had a Berlina VS II, Did the same thing going up hill. Had it checked out, nothing to worry about has something to do with the climate control system. I never had any ongoing issues as a result til my wife wrote it off.
    VY S Sedan
    Sep 2007
    Quote Originally Posted by Degeko View Post
    The size of the vacuum tank is not a design fault at all.
    Putting a larger tank on it will only mask your faulty leaking vacuum system.
    It is not normal for this to happen,it's caused by a loss of vacuum in the system.
    As mentioned above,check the one-way valve at the inlet manifold,check the vacuum actuators under the dash that control the mixing doors.If the one-way valve is OK,the second most likely cause is the vacuum actuators.They get a hole in the diaphragm and don't hold vacuum.
    To diagnose these properly you need a vacuum pump/gauge and knowledge of how the system works.
    vy belina
    Sep 2006
    Easy to fix,tried bigger tank, if it worked on leaving the factory it should be easy to fix. The vacuum cylinder under right side of console needs replacing, did mine and no more trouble. Qector
    aaronevolution's Avatar
    aaronevolution is offline Donating Member
    TURISMO VZ SS 6.0
    Mar 2011
    Hastings, Victoria
    My VR, VY, VZ and my brothers VT, VU and VZ all do this. Surely your not saying there is something wrong with all of them? I'm pretty sure it's normal. Nothing to worry about.
  1. Canberra hill climb
    By coolvxss in forum The Pub
    Last Post: 06-05-2007, 10:30 PM
  2. Down hill assist
    By VZ219 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 12-02-2007, 03:37 PM
  3. Down Hill Desecent Control
    By sittingduckau in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 08-06-2006, 06:02 PM
  4. Car loses speed down hill
    By richie in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-06-2005, 04:13 PM
  5. Up Hill acceleration
    By veclubby in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-12-2004, 02:38 PM
