Results 1 to 6 of 6
Thread: Rear end rumble
    VY "S" Ute
    Mar 2007
    Default Rear end rumble
    Not sure but I have what I think is a noisy rear wheel bearing. The noise is related to road speed sounds like a bearing but I am not sure. Unlike a diff noise which come and goes with the load this noise just increases with speed and seems to go away at higher speed but very evidnet at low to around 80 - 90 k's.
    It is and interupted rumble (if that make sense)
    Slowing down the noise appears louder but that may be becuase there is less road noise and wind noise
    So my question is if my discription is acurate enough what could it be?
    Holden2gether's Avatar
    Holden2gether is offline The short,chunky fella
    VY S
    Oct 2006
    Christchurch,New Zealand
    Could be a bearing although usually if a bearing is poked it gets noisier with an increase in speed,the noise probably wouldn't drop off either at the higher speeds.It might change pitch from a low rumble to a high whine or something similar.Sounds silly, but have you checked your brake pads?
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Does the noise change with a side to side movement of the car while driving? That is a dead give away for a wheel bearing.
    davey g-force's Avatar
    davey g-force is offline I'm a sceptic...
    Phantom MY09 VE SSV A6 & Holden Cruze CDX M5
    Sep 2005
    "...the winner is..."
    I've got a rear end rumble at the moment, but that's cos I ate beans last night!
    ...sorry guys, couldn't help myself...
    Quote Originally Posted by CSP (aka Rufys) View Post
    Look, all the update is going to be is like going from VX to VY or VY to VZ. Same car with different front/rear ends and updated interior. But it will be the VF, not the VE II.
    VY "S" Ute
    Mar 2007
    Quote Originally Posted by Not_An_Abba_Fan View Post
    No, does not change, stays constant with side movement
    Could be a pad touching slightly on the disc? Maybe slight park brake drag? Like I said it is almost an intermittant sound which increases and decreses with speed more noticable a lower speeds
    2011 Commodore SV6 SII
    Sep 2006
    I might have the same thing. Mine is like tyre noise coming from the rear.
    It only happends when going at around 60. It disappears if I put my foot on the accelerator. If I take my foot off, it comes back again.
    I asked about it in the last service but they just found it to be tyre noise and it will probably go away with the next set of tyres or a wheel alighnment.
  1. rumble noise
    By tonys vz in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 24-10-2007, 08:24 PM
  2. big rumble
    By 03vyPplater in forum VY Holden Commodore (2002 - 2004)
    Last Post: 08-01-2007, 11:18 PM
  3. exhaust rumble
    By adrian222 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 29-09-2006, 07:56 PM
  4. Rumble and grind!
    By BR377 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-04-2006, 09:14 PM
  5. Bad Rumble!!!
    By Wombatclay in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-12-2005, 09:30 PM
