Page 1 of 2 12 LastLast
Results 1 to 25 of 29
Thread: Heres how 2 remove jammed cd's from Blaupunkt sterio.
    VY Executive
    Apr 2007
    Cool Heres how 2 remove jammed cd's from Blaupunkt sterio.
    A cd got jammed in my stereo a few weeks ago so I got a quote from a few places which all said it would cost around $150-$200 2 remove. I had it in at holden for a separate issue a few day's ago and mentioned it 2 the guy in the service department who came out and had a look. With the ignition off he pulled out the 2 fuses marked (radio/cell phone) and then put them straight back in and sure as hell the cd came straight out. Apparently it is a quite common problem with these stereos so I thought it might save some of u guys a bit of money and heartache.
    VYII Spac S/C
    Sep 2005
    If this is the error that occurs when your player decides to "eat" your cd, same result can be achieved by disconnecting, then re-connecting your battery.
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Now if the poll was 'Would you let someone else root your missus' then the answer would be different. That would depend on what their missus looked like and if you could root them.
    VY Executive
    Apr 2007
    Thank's for that but if u do it this way u dont have 2 enter any codes or reset radio stations like u would if u disconnected the battery.
    VYII Spac S/C
    Sep 2005
    You dont have to re-enter codes when you disconnect the battery, trust me.
    VY Executive
    Apr 2007
    Thumbs up vy
    well u learn a new thing everyday.....I have only had my vy for a couple of months but the other cars i have had have lost there memory settings when u disconnect the battery....but now i know THANKS.
    VYII Spac S/C
    Sep 2005
    You may still have to re-input your radio stations (dont know, never use the radio) and you do have to reset the clock, but yeah, i've never had to input the secruity code.
    davey g-force's Avatar
    davey g-force is offline I'm a sceptic...
    Phantom MY09 VE SSV A6 & Holden Cruze CDX M5
    Sep 2005
    "...the winner is..."
    Krazyboris is right, disconnecting then reconnecting the battery is another way to solve this, but I spose it amounts to the same thing as pulling out the fuse really. Some guys also pull out the head unit and replace it, which will also amount to the same thing.
    FYI, when you disconnect your battery, you don't lose your radio station presets. The only thing you have to reset is the clock.
    Quote Originally Posted by CSP (aka Rufys) View Post
    Look, all the update is going to be is like going from VX to VY or VY to VZ. Same car with different front/rear ends and updated interior. But it will be the VF, not the VE II.
    Lumps of cheese's Avatar
    Lumps of cheese is offline Who wants chowder?
    MY08.5 VE V8 CALAIS/2010 Hilux SR D4 Dual cab 4x4
    Boulder Crusher Champion! Balloon Park Champion! Action Fish Champion! 501 Darts Champion! Frogger Champion! Jungle Kid Champion!
    Nov 2005
    Warrnambool
    Sep 2005
    Quote Originally Posted by juzsvy View Post
    Doesn't it depend on how long the battery/fuse is disconnected for?
    Yeah probably. I've had my battery disconnected for a couple of hours before and didn't lose the radio station presets.
    Perhaps really long periods will cause the memory to be lost...
    andrewmac's Avatar
    andrewmac is offline Not to be trusted
    S2 VE SS
    Jul 2005
    Im assuming this is only for the single stack and not for the 6 stacker.
    I tried it with mine (4 cds stuck and its saying mechanism error) and didn't work unfortunately.
    Does anyone have any idea if there is a trick to get these ones out ?
    I've tried to pull the whole player out with the coat hanger trick but it wont budge either.
    Sep 2005
    Na, mine's a six stacker and it worked for me.
    Did you try disconnecting the battery / fuse for a long period of time?
    Also, if you PM Phreddy, he might be able to tell you how to get the headunit out. He's made up a couple of little tools with coat hanger wire and it literally takes him 3 seconds to pull it out!
    VYII Spac S/C
    Sep 2005
    I made mine up the same as phreddys, but out of brass wire. Worked a treat. The secret is in the hooks on the end, make them nice and deep, and you should'nt have a problem.
    andrewmac's Avatar
    S2 VE SS
    Jul 2005
    I have managed to get the unit out but Ive had a look at it and i doubt i can fix this issue.
    Do you guys reckon holden would say a warranty is voided if i have taken it out ?
    I'm not gonna tell them I've taken it out but just wondering if they would claim that.
    Sep 2005
    Quote Originally Posted by andrewmac View Post
    Na, doubt it. You took it out AFTER it was playing up, so you shouldn't have any problems. But like you said, you're better off just not telling them you've had it out...
  15. #15
    vy commodore
    Nov 2009
    Hi guys i have had this problem with my head unit i did al of the above got the cd out but now audio system won't work keeps saying voice in on the display and does nothing else. please help
  16. #16
    03 VY Supercharged 3.8L
    Stack The Cats Champion!
    Nov 2008
    Tullamarine, Vic
    Quote Originally Posted by davey g-force View Post
    Uhh, not exactly. Recommended time when doing the battery is 5 minutes. I did it just the other day when my CD player ate my CD, and i changed the serpentine belts that day too.
    Doing the above will not remove your radio stations and the PIN code is stored in the ECU of the vehicle, so that's all automatic. You will loose the clock as stated and your vehicle will need to relearn how to drive (your fuel usage will increase as the PCM learns whats best for the engine).
    EDIT: And if it's a V8, make sure you do the idle run to set the IAC valve position.
  17. #17
    06 VE SS
    May 2009
    Rockingham, WA
  18. #18
    Nov 2008
    Tullamarine, Vic
    Quote Originally Posted by scouser king View Post
    How do you stop your drunk mate's trying to put 3 cd's in at once ?LOL
    Hit them with a clublock. If they are drunk and they are doing that they can be dangerous to your and other road users safety.
  19. #19
    Sep 2005
    Quote Originally Posted by alien View Post
    Uhh, not exactly...
    Doing the above will not remove your radio stations and the PIN code is stored in the ECU of the vehicle, so that's all automatic. You will loose the clock as stated...
    Uhh, how's that different to what I said?
  20. #20
    Nov 2008
    Tullamarine, Vic
    It's not :S I quoted you in that post so that people would see it's what you said. I only repeated it for other members who only decide to read my post.
    Where mine differs is that it also says what else disconnecting the battery will do to your vehicle.
  21. #21
    -scyth-'s Avatar
    -scyth- is offline Im alright its the others
    VZ Wagon 05
    Nov 2008
    Quote Originally Posted by Juzo View Post
    not really. I have a vy berlina 6 stack installed in my vz & i recently went overseas for 8 weeks, so in the finals hours before leaving for the airport, i disconnected ONE terminal only. when i came back home, i reconnect the battery & it started 1st kick. all my radio settings were swish as well.
  22. #22
    -scyth-'s Avatar
    VZ Wagon 05
    Nov 2008
  23. #23
    VY II Calais
    Nov 2008
    My VY calais has the 6 stack BP CD player and did the same not long ago, I really got the sours up and turned it off and went inside for a while, when I came out I pressed and held Eject for 3 seconds and it switched to eject all and they all came out one at a time. My wife then informed me that that happens to it all the time and you just leave it alone or turn it off for a while and it sorts itself out?? I don't know if that helps or not
  24. #24
    VY II S
    Aug 2010
    Queensland
    I have a VY II S and I've tried removing both fuses for about 20 seconds and putting them back in the ones marked Radio/Cell Phone and also removing the battery leads for about 10 minutes and both failed, I still receive the CD Error message. I'm not sure exactly what's up with the CD player.. as we bought the car with the CD Error so I'm not sure if there is a CD stuck in it or just some other problem.
    Once again VY II S and single disk blaupunkt cd stereo.
    Any idea's????
  25. #25
    VY II Calais
    Nov 2008
    The other thing that worked when the fuse removal thing didn't work was trying to put another cd in and it would "dislodge" the jammed one from basically the mouth of the cd player then it would eject the jammed one properly
LinkBacks (?)
  1. 6 Stacker won't load CD's
    By Jockstar73 in forum Car Audio
    Last Post: 12-11-2007, 09:42 AM
  2. best brand blank CD's
    By New2Holden in forum Car Audio
    Last Post: 01-06-2006, 10:01 PM
  3. Can u Burn wma CD's on WMP??????
    By BANGERS88 in forum The Pub
    Last Post: 04-12-2005, 12:39 PM
  4. Cruising Cd's
    By HoZy in forum The Pub
    Last Post: 04-11-2005, 04:32 PM
