loosing vacuum in face position when going up hill , all piping in good order, any suggestions.
Last edited by qector; 29-04-2007 at 03:33 PM. Reason: found actuator diaphram leaking ,replaced for $18.15, that may have fixed it. qector.
Unfortunately, if the engine doesn't produce enough vacuum (ie:- under heavy acceleration or load) it does cause this to happen, though only temporarily. No suggested fix.
To all the BA's I've blown the doors off, GIVE UP!!!
This has been covered before several times. Here's the latest thread on the subject:
Vents change up hill
