Hi
I have what I think might be a minor problem, every time I lock my VY commodore the horn beeps twice. It's been only happening since a last two days
Any solutions? Thanks
Borrow money from a Pessimist-They DON'T expect it back!
Not really a problem.. Well nothing to worry about dude!
You can disable this feature in the options menu. When you first turn the ignition on your car the display will say 'Options Menu'. You then need to press the arrow buttons to access this feature.
From there you can scroll down until you find it and disable the horn tones when arming your alarm system.
Hope that helps... If i haven't been clear someone else will explain
Thanks very much for that, believe it or not I've had this car for nearly three years but was unaware of the options thing. Looks like I hardly know my car!!
I just found out the problem, the passenger door lock does'nt depress. It's staying open. I've had this problem before and the door actuator was replaced under warrenty. I'll take it back to the dealer 'cos it's been only 15 months since it was replaced and the reciept says 2 years warranty on parts.
Thanks for the reply.
No worries mate. While your there pick up an owners manual if you dont have one. All the detail about guiding yourself thru the options menu is all there
after your reply, I dug out my one and at this very moment going through it
thanks again
Isn't the horn let you know there something wrong with the locking system or alarm. I remember reading it somewhere. I mean it just can't suddenly happen, something has ti make the horn beep.
hi, my crewy does it when one of the doors isnt shut properly.
heres my ride, i know its not much but its mine
http://forums.justcommodores.com.au/...-ss-crewy.html
and heres my new project
http://forums.justcommodores.com.au/...ml#post1104629
CHECK OUT MY RIDE
IF I WAS HELPFUL TOO YOU CLICK MY SCALES
"Girls are like domain names, all the good ones are taken."
I had to replace the passenger door lock on mine last week.Can't buy the actuators by themselves any more.$100 bucks to fix.Don't how much Holden would charge on labour though
I also had this problem on and off lately for first time, its the passenger side front lock not pulling down and locking when central locking is activated.
Essentially those little beeps are warning you you car is NOT secure![]()
Raptor Superchargers - Boosting S1/S2 3800's, Ecotec's and Alloytec's
I had the same problem with both of my driver side doors, got them fixed under waranty as well with new actuators no problems since.
