Results 1 to 6 of 6
Thread: driveline clunk vy
    vs ute
    Mar 2007
    Question driveline clunk vy
    Please Help: I Have A Vy Ss S2 5.7 6 Speed Seems To Be Very Loose In Driveline When Slowly Moving In And Out Of Driveway/shed Have Asked Holden Dealer To Check On Last Service And They Said Its Find Some Are Just Like That I Need To Know More About This Clunk Noise As Warranty Is About To Expire Car Has Only 48000klm 2nd Owner Thanks
    vy series 2 v8 berlina
    Dec 2006
    Quote Originally Posted by vs hay hauler View Post
    Have you checked the universal joints & centre bearing on the tail shaft or your LSD might need adjustment
    2010 Isuzu FXZ 1500 on 20's
    Oct 2006
    Bogan enclave
    Wouldn't be too concerned about it mate. A bit of diff backlash is quite normal. Mine does exactly the same thing and you'll find that a lot of other members on here get it as well.
    I'd like to make a suggestion though. If your car is just about to run out of warranty and you're concerned at all, I would suggest getting a vehicle inspection from an independent source. Like RAC in your state. Then if there is an issue with the car, Holden can't bull**** their way out of it.
    holdensupporter2005's Avatar
    holdensupporter2005 is offline Donating Member
    VE SV6 Commodore - Silver
    Sep 2005
    N.E. Vic
    Quote Originally Posted by Bravotwozero View Post
    Good suggestion, pity I didn't think about getting this done before my warranty ran out
    http://forums.justcommodores.com.au/signaturepics/sigpic17276_1.gif
    CHECK OUT MY RIDE
    IF I WAS HELPFUL TOO YOU CLICK MY SCALES
    "Girls are like domain names, all the good ones are taken."
    davey g-force's Avatar
    davey g-force is offline I'm a sceptic...
    Phantom MY09 VE SSV A6 & Holden Cruze CDX M5
    Sep 2005
    "...the winner is..."
    Do you get the clunk when you're rolling along in slow traffic and you slowly accelerate and/or back off?
    I had that same thing and was at first told it was normal but it got worse and worse and started making all kinds of horrible noises. Turned out my diff was shot (only 40,000 Km on it at the time). Holden were reluctant, but I jumped up and down a bit and got them to replace it with a new one under warranty. $1100 worth of diff apparantley. So yeah, that's my experience...
    Quote Originally Posted by CSP (aka Rufys) View Post
    Look, all the update is going to be is like going from VX to VY or VY to VZ. Same car with different front/rear ends and updated interior. But it will be the VF, not the VE II.
    SS_ute's Avatar
    SS_ute is offline Two Steps Ahead
    vy ss ute
    Apr 2007
    southern adelaide
    i had the same prob in my ss ute and it turned out to be the diff so i replaced it with a kaaz diff never had a prob since and so much better than the standard lsd
  1. driveline vibrations
    By v unit in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-05-2006, 11:30 PM
  2. VT driveline.can I start it out of the car?
    By petespipes in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-04-2006, 10:30 PM
  3. clunkity clunk clunk
    By webbo1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-03-2005, 12:30 AM
  4. Problem with VN driveline
    By vinnywelsh in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-08-2004, 02:03 PM
  5. Driveline vibration
    By Bulldog in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-06-2004, 12:02 AM
