Results 1 to 7 of 7
Thread: VY Commodore ABS
    VY series 1 Acclaim
    Apr 2007
    Question VY Commodore ABS
    This is my first post,
    I have a 2003 series 1 VY commodore at 56,000ks the ABS light was illuminating and the Internal Module was replaced due to fault code 71 present these are the words on the warrany invoice / Report.
    At 75,000 ks it started again with the ABS fault coming on when the car is started and the system checks are being completed. It seems that it happens less frequentley when you have your foot on the brake as you start the car not sure why however its a real pain starting the car 3 times just to get the ABS to work.
    I used to have a VT and would short out the pins, read the flashes and interperate the codes, can anybody tell me which pins to short out on the plug under the steering wheel on the VY, and where to read the codes? I have read up on the 16 Pin OBD-II style connector however the pins appear to be in different places.
    The way I figure it if I get the same code 71 I can ask for a warranty on the repair as they say the holden parts replaced have a 2 yr 50,000k warranty.
    Any advice is appreciated
    davey g-force's Avatar
    davey g-force is offline I'm a sceptic...
    Phantom MY09 VE SSV A6 & Holden Cruze CDX M5
    Sep 2005
    "...the winner is..."
    Hmmm, good question for Dr Bob methinks:
    Ask the EX-Holden Technician
    ...Our resident Holden Technician and guru!
    Quote Originally Posted by CSP (aka Rufys) View Post
    Look, all the update is going to be is like going from VX to VY or VY to VZ. Same car with different front/rear ends and updated interior. But it will be the VF, not the VE II.
    VY series 1 Acclaim
    Apr 2007
    Further search through the posts on this very informative websites relating to other models led me to try starting the car with the mode and set buttons held, this opens a screen on the main speedometer window that provided,coolant temp, fuel on remaining etc, it also provide a window called fault codes, however there was just rows and rows of zeros? does this make sense to anyone??
    Again any help is appreciated
    vt ss
    Jul 2009
    Hi i am having trouble with my ABS light on the dash all of a sudden, i pulled code 21 and 25 and 28 which is front right and left wheels speed sensors. Do i need to replace the abs sensors in the hubs or is it something else? Thanks
    VYII Equipe S/wagon V6
    May 2009
    Melb, Vic
    Always start from cheapest and up I'd check the plugs for them first
    Cheers,
    Dave
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    vt ss
    Jul 2009
    Thanks guy's i checked the plugs and they looked ok, i cleaned the pins and the waterproof seal seems ok on the plugs. The battery is next. Just one more thing, it does not seem to happen when driving around town but as soon as i hit 100 on the freeway tends to activate the fault that seems a bit weird.
  1. Commodore S ....Commodore SS... is there a difference..??
    By Hairy Eater in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-12-2009, 03:23 PM
  2. Do VN V6 Commodore injectors fit a VR V6 commodore
    By ozzybloke01 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-09-2007, 04:43 PM
  3. VN commodore exhaust into VR commodore
    By The Darkness in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-11-2006, 09:38 PM
