Results 1 to 8 of 8
Thread: White Smoke
    VY Supercharger
    Jan 2005
    Unhappy White Smoke
    The wife reports that she noticed a cloud of white some from the exhaust of the Commodore. The ride is a 2004 VY S Pac Supercharged and has done about 21,000ks. This happened at the McDonalds drive thru.
    What could be wrong.
    Thanks all.
    2003 VY S1 Commodore Berlina sedan
    Oct 2005
    Wellington, New Zealand (Yes i know yet another KIWI)
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    ford
    May 2005
    in a ford
    i dont reckon you got anything to worry about, as long as its not doin it all the time
    dagar187's Avatar
    dagar187 is offline ls1nder
    VZ-SS
    Dec 2006
    nsw
    VY Supercharger
    Jan 2005
    Thank you all for your response. Got low mileage becuase got another ride which we use regularly. Commodre is used occasionally.
    Ok Update time:
    It's about 30 degrees, i can still see white condensation in the air, but cannot see white smoke from the exhaust. If i put a piece of cloth against the exhaust, it gets warm and damp then the dampness dissapears fast. if i press the accelerator, water seeps out of the exhaust.
    Have burnt rubber recently and Check engine warning came on!
    Should i be worried?
    What should i do?
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    The dampness and water are normal, it proves your cat is working. The engine check light came on because the transmission would have chucked a spaz cos you weren't moving. The light should be off now? It just logged an error in the ECU, I think you can still check codes on a VY the same as VT-VX.
    davey g-force's Avatar
    davey g-force is offline I'm a sceptic...
    Phantom MY09 VE SSV A6 & Holden Cruze CDX M5
    Sep 2005
    "...the winner is..."
    I reckon it's condensation cos you drive the car so little. N.B.D.
    Quote Originally Posted by CSP (aka Rufys) View Post
    Look, all the update is going to be is like going from VX to VY or VY to VZ. Same car with different front/rear ends and updated interior. But it will be the VF, not the VE II.
  1. Vy Blowing Lots Of White Smoke
    By emma.henningsen in forum VY Holden Commodore (2002 - 2004)
    Last Post: 17-10-2007, 11:47 PM
  2. mazda 626 - blowing white smoke when cold
    By lowrida56 in forum The Pub
    Last Post: 01-05-2007, 10:54 PM
  3. White smoke...
    By HoZy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-07-2006, 09:47 PM
  4. VN 5 Litre white smoke exhaust
    By outbackjack in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-01-2006, 09:13 AM
  5. need help about losing oil and white smoke
    By vk dude in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 23-01-2006, 11:28 PM
