The electric tilt and height seat in my Berlina has packed a sad, by the looks of it the rear adjuster has destroyed itself. Whats broken is the blue plastic screw drive that attaches to the seat and threads into the worm drive on the motor. Can you buy this piece seperate and how do you get the pin out that attaches it?
Cheers, Jeff.
Cancel that question, problem solved. For anyone else that has this prob. On VZ's they changed the part to a steel one, you can't buy it seperatly but I went to a wrecker and got one. You need to file off the end of the pin that holds it to the seat and then it's a matter of just pulling off the old one and screwing the new steel one onto the shaft, drill a hole in the pin for a split pin and reassemble.
Cheers, Jeff.
Hey Thanks.
Just had the same problem on my VY Calais.
Good to know that the Blue Nylon piece is available in a steel unit, form VZ.
I go to the wreckers.
If someone made them, they would have a little gold mine.
Cheers legs
