Results 1 to 6 of 6
Thread: removal of clubsport badges
    hothouse vy s is offline supercharged hothouse VYS
    VY Commodore S
    Feb 2006
    Default removal of clubsport badges
    i was wondering if anyone knew how to remove the silver badges on the car.. i have a vy clubsport and the silver clubsport badges have lost colour so i want to remove them and put new ones on..
    can anyone help with the removal?
    cheers
    SuperCharged Hothouse VY S
    VY Acclaim S1
    Apr 2006
    Perth, WA
    when i took the badges off my acclaim i just pulled them off. they all broke so they couldnt be used again but it got them off the car. some of the sticky residue was left on the car so i got that off with some citrus cleaner.
    theres probably a better way, but it worked..
    matt
    hsv_punk's Avatar
    hsv_punk is offline I Just Want One
    VYII Berlina V6
    Jan 2005
    VIC
    Wet the badges, then maybe a quick warm by the hair dryer (not very warm, just a little), then slide some dental floss (preferred as it is soft)/fishing line/string behind the badge in a sawing type motion across the badge.
    Should come off with no damage. Then you should simply be able to roll the remaining glue off with your hand. Job done.
    Search for 'badge', 'debadging' or similar for more info. But the above is the method I have used a few times and it has always removed them with no damage.
    ..::HSV Punk::..
    VY Acclaim S1
    Apr 2006
    Perth, WA
    VY Commodore S
    Feb 2006
    Jun 2004
    brisbane
    the way i always do it is to get a length of thin fishing line & slowly slide it back & forward like a saw behind the badge while gently pulling it sideways.works fine never had a problem.just get some prepsol or tar & glue remover to get rid of the residue.can be a bit of a pain sometimes to get residue off but just take your time so as not toscratch any paint.good luck.
    cheers
    warrick
  1. badges on or off?
    By BANGERS88 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-06-2006, 07:31 PM
  2. VS Badges
    By ozzie_online88 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-06-2006, 09:26 PM
  3. VS Badges onto VR
    By AirStrike in forum General
    Last Post: 22-02-2005, 08:00 PM
  4. Badges
    By wooly72 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-02-2005, 01:40 PM
