Results 1 to 7 of 7
Thread: Strip down the side of the Vy
    Silver surfer is offline Banned
    04 VY Executive
    May 2007
    Default Strip down the side of the Vy
    How is the black strip down the out side of the car stuck there???
    Is it hard to remove?????
    VS II V6 Berlina
    Nov 2005
    It's held there with doble sided tape and also sikaflex (used for w/screens)
    to remove you'll need a razor blade or knife and flat blade screw driver or flat lever bar then lever gently and cut glue and tape.
    The Windsurfing VY Wagon's Avatar
    The Windsurfing VY Wagon is offline Donating Member
    VY S2 04 S/W
    Oct 2006
    Cairns, QLD
    Should be real thin tape across the top ot the moulds. I have seen it done before but a little paint got ripped off.
    You could have it masked off and sprayed the same colour as the car.
    If you do get the moulds off with out damaging the paint then just some metho should remove the sticky resdue from the clear coat.
    Windsurfing.....
    This is what you call a real sports wagon, BOUY!!!
    VY Acclaim S1
    Apr 2006
    Perth, WA
    mine were held on with double sided tape and sikaflex. sikaflex is an absolute bitch to remove, there are no chemicals i know of that are up to the job. since its proving to be so hard to get the sikaflex off, im going to spray mine the same colour as the car and stick them back on
    matt
    04 VY Executive
    May 2007
    Farlig's Avatar
    Farlig is offline Donating Member
    Y-Series Clubsport
    Jan 2005
    i painted mine same colour as car, if you dont mind having them on there; its the safest way to not rip the paint off the door skins.
    VY S2 04 S/W
    Oct 2006
    Cairns, QLD
    Hit the Sika with a hot air gun, should let it peel right off unless it's some other type of branded stuff which is a bit different to what we use to use on the boats...
    Windsurfing.....
  1. side strip
    By wayvr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-03-2007, 07:56 AM
  2. strip
    By pr0n in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-02-2007, 10:38 PM
  3. Drag strip down sth-eastern side--
    By OFFiTS in forum General Discussion
    Last Post: 23-05-2006, 09:25 PM
  4. Strip on side of car
    By Cal.oz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-11-2005, 08:03 PM
