Register - Members List - Calendar - Mark Forums Read -
Go Back   Just Commodores > Holden Commodore Related > VY Holden Commodore (2002 - 2004)
VY Holden Commodore (2002 - 2004) Talk about anything relating to the VY Holden Commodore.
Reply
LinkBack Thread Tools Display Modes
  #1
Old 28-08-2007, 07:07 PM
Raptorsc's Avatar
RAPTR6
Ride: VY V6 EXEC II 208rwkw
Trade Rating: (0)
Raptorsc Executive
Default Speaker replacement
People ......... Raptor needs advice
I am thinking of changing all the speakers in the VY for something better, thinking FUSION brand at this point in time.
What are the speaker sizes in the VY? Need to know for when I go to buy.
Of course I could just roll down to the local carsound joint and get this info but also like to see what people have to say from experience.
At this point I am not thinking about changing any of the other components, is that a problem?
__________________
Raptor Superchargers - Where blow means 3800's, Ecotec's and Alloytec's GO
Click link below for buildup of Supercharged VY V6 .....now showing 208RWKW with Raptor ProStreet Intercooled system
http://forums.justcommodores.com.au/...ad.php?t=42803
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Google Bookmark this Post!Yahoo Bookmark this Post!Bookmark to AskJeeves!Bookmark to Slashdot!Live Bookmark this Post!Spurl this Post!Reddit! Wong this Post!
Sponsored Links
  #2
Old 28-08-2007, 09:55 PM
hothouse green
Ride: VY S pack s1
Trade Rating: (0)
surfindude Executive
i wouldnt go anything else but alpine but the problem i see that ur going to have is that the standard head unit isnt going to put out enough thump to power good speakers to the max anyways
please correct me if im wrong
let us know what u go for
  #3
Old 29-08-2007, 06:36 AM
davey g-force's Avatar
I'm a sceptic...
Ride: Phantom MY09 VE SSV A6
Trade Rating: (0)
davey g-force Calais
The standard speaker size is 6", however you can squeeze 6.5" in there if you modify (cut/file) that plastic plinth which they are screwed into. I would get splits for the front, that way you can replace the factory tweeter as well (located in the top corner of the dashboard, next to the windscreen).
You should still get better sound with just speakers alone, although you wont get the best from the new speakers without an amp.
__________________
See My Old Ride Here ...And Here
Pics of my new ride coming soon.
"To the optimist, the glass is half full. To the pessimist, the glass is half empty. To the engineer, the glass is twice as big as it needs to be."
  #4
Old 29-08-2007, 06:46 AM
Raptorsc's Avatar
RAPTR6
Trade Rating: (0)
Raptorsc Executive
Yep, getting the message on an amp. Is that 6" round I take it?
__________________
  #5
Old 29-08-2007, 10:39 AM
VZ 3.6
Ride: VZ 3.6 Exec
Trade Rating: (0)
colk Executive
Hi Raptorsc, yes they have six inh round speakers, most 6inch should fit fine.
However I have a question for you guys, When modifying to fit 6.5inch speaker, what is the best way of modifying the speaker bracket in the door to fit.
I had a problem with a friends VS once and after filling the plastic etc it tended to vibrate a little, I am hoping its not the same for the VY/VZ? Is there dampening or sealant that is good to use?
I am looking at soundstream tarantula 6.5" splits for the front of my VZ, has anyone had experience with these speakers or do you have any suggestions of brands etc around $250 - $300 mark?? (PS they will be amped)
Cheers guys
  #6
Old 29-08-2007, 10:49 AM
cxcxcxvcvcvc's Avatar
Ride: vs calais eco
Trade Rating: (0)
cxcxcxvcvcvc Calais
fusion isnt to bad if your looking @ running of a head deck ect but as posted if you want and decent sound then you will be looking at an amp i have fusion amps and subs in my car but i use sony xplod splits up front with just the factory rear speakers runnin of the fac head deck. if your going to get an amp then its all personal choice (or how big your wallet is lol) but i would look at the jl splits for around $300 there pretty good.
  #7
Old 29-08-2007, 12:51 PM
I'm a sceptic...
Trade Rating: (0)
Quote:
Yep, definitely 6" round.
Quote:
I just used a dremel to grind away at the surface. I'm sure you could achieve the same thing by hand using a file. I only had to grind away about 3mm all round to get my 6.5's to fit. That was for Jaycar 6.5's anyway - other brands may be different.
BTW, doing this means you lose the plastic which covers the speaker cone/magnet to stop it from getting damp. I figured that doesn't matter since the amount of water that actually gets in there is minimal (a drop or two at worst) and that the Jaycar speakers have Kevlar cones. I've had them in there for about two years now without any problems, however some people in this situation still like to cover the back of their speakers with a sheet of plastic or equivalent to stop them getting damp.
__________________
  #8
Old 29-08-2007, 01:23 PM
VZ 3.6
Ride: VZ 3.6 Exec
Trade Rating: (0)
colk Executive
Thanks, I have a soundstream lil wonder 2.40 amp spare which will be sufficiant to run the front splits 125Watt RMS x2, I am replacing this amp previously running my sub for a monoblock.
I might have a look into JL Audio aslo for the splits because I have heard they are quite good.
I will have a look at a few demo boards and reviews before my purchase and post how they turn out once installed.
  #9
Old 29-08-2007, 01:28 PM
Joey_19's Avatar
Ride: VY SV8 HBD---mmmm LS1
Trade Rating: (0)
Joey_19 Executive
no matter wat speakers u get ur not gunna get full potential from the jus running em off the headunit u need an amp-although the will sound better then stock ones i guarentee u that---i have JL speakers there really clean and crisp but thats my choice and there a bit expensive for some1 on a budget i guess
__________________
JOEY'S NEW RIDE VY SV8 -LS1-http://forums.justcommodores.com.au/...y-sv8-hbd.html
  #10
Old 27-09-2007, 06:21 PM
phazer's Avatar
Ride: vs acclaim
phazer Executive
HI guys. I own a Vz and I've just replaced factory speakers with aftermarket ones....problem is that now I have no sound at all. Could someone with a bit of knowledge in this department give some advise please. I would have posted this under VZ, but could'nt find an appropriate thread. Any help would be great.Thanx
Probably something very obvious.......
  #11
Old 27-09-2007, 08:59 PM
juzo's Avatar
Appy-polly-loggies
Ride: 05 VZ SS M6 / 02 rodeo td dual cab
juzo Caprice
Wires hooked up wrong?
I run pioneer in my vy, splits in the front and 6 x 9 in the parcel shelf.I still had the stock unit in when i changed them and found it made a little bit of difference.I changed the factory deck with a pioneer deck and added an amp and it is excellent, would certainly recommend it.
__________________
How important do people have to be before their murder becomes an assassination?
  #12
Old 28-09-2007, 06:41 AM
Raptorsc's Avatar
RAPTR6
Trade Rating: (0)
Raptorsc Executive
When you added the pioneer deck did you lose the control functions from the steering wheel? And also the other information that normally shows on the dash?
__________________
  #13
Old 28-09-2007, 03:31 PM
=SKB='s Avatar
Ride: N/A
Trade Rating: (0)
=SKB= Hitchhiker
There are adapter cables available for certain brands, namely Bluepoint and Clarion, that allow you to keep steering controls. Some after market adapters can cover other brands. This is covered a bit in the audio thread.
  #14
